Repairing Bumper Cracks?
Old Aug 16, 2018 | 06:13 PM
W. M. Hellinger's Avatar
5 Year Member
W. M. Hellinger is infamous around these parts
I have a 2008 GTC with a couple minor cracks down low in the front bumper skin. I have the bumper skin off. I ask if there's a recommended glue type or plastic welding type to heal them up? I'm not aspiring to concours restoration... just heal up the cracks while the bumper skin is off.
Old Aug 17, 2018 | 09:41 AM
Rons GT Speed's Avatar
Rons GT Speed is infamous around these parts
Hello Hellinger. I am also in the process of repairing cracks on the lower portion of the front bumper. If you do some research on YouTube on how others have used the material, You might find this to be an durable and acceptable repair product. 3M 8116 PANEL BONDING ADHESIVE W/8571 APPLICATOR.
Ron
Old Aug 17, 2018 | 01:27 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Having repaired my bumper twice, I realized the essence of the problem. The crack was caused at a stress point where it curves around the fender. Fixing the crack doesn't eliminate the stress point. To repair your bumper skin properly, you must remove it and layer fiberglass behind the bumper to reinforce the stress points (e.g. both corners). Once you have cured the fiberglass, you can repair the crack itself using conventional plastic bumper repair materials and then prep and paint the entire bumper. Not really a DIY project for most owners. However, if you don't relieve the stress first, any cracks will reappear. I redid my bumper properly five years ago and haven't had an issue since. It wasn't that expensive as I simply removed the bumper and took it to my local body shop. It was A LOT cheaper than a new bumper!!
Old Aug 17, 2018 | 03:25 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Agree with Mr. PMS. I use J-B Weld the slow dry compound. Rough up area with 60 or 40 Grit apply thin layer of JB Weld. Then I lay squared tight weave fiberglass material on top of applied J-B Weld. Than, smooth another layer of JB Weld over the fiberglass. Use a small applicator normally used for Bondo. Repaired motorcycle fairings and plastic composite bumpers this way, all resulting in long-term success.
Old Aug 24, 2018 | 11:11 AM
5 Year Member
Ron
Thank you Ron. Per your recommendation, I surfed YouTube concerned with the 3M 8116 product, which appears to be for glue bonding (metal?) panels. In my YouTube surfing related to the 3M 8116 product I stumbled onto 3M Automix EZ Fix Flexible Patch system, specifically for bumper skins, which I think I'll give a try and see how it works.
Old Sep 2, 2018 | 12:11 AM
Sorry Hellinger for the response delay. I was away. Thank you for your find. I will look at this for a repair method and product use.
Ron
50redlands
Bentley
14
Feb 23, 2015 11:52 AM
kem
Mar 14, 2007 10:31 PM
Greyghost
Dec 5, 2003 05:10 AM
