My first mod
Old Apr 25, 2019 | 07:31 PM
flyer39's Avatar
flyer39 is infamous around these parts
My first mod
Just installed the Grom bluetooth unit. Works really well. Took about 5 minutes. I'd appreciate any tips anyone might have about routing the mic wire to the overhead console.
Thanks!
Old Apr 26, 2019 | 04:43 PM
Rico.Adams's Avatar
5 Year Member
Rico.Adams is infamous around these parts
Thanks!
Through the top of the glovebox up the side trim under the front of the headliner and leave the mic at the side of the overhead light box or if you want to be more creative the 2 black circles which look like small speakers, one is the original mic which you don't use and the other is a dummy, you could swap them over and use the dummy drill a same size hole as the new mic and pop the mic into it ...
Old Apr 26, 2019 | 08:19 PM
flyer39's Avatar
Thanks...do you think I really need to cut a hole in the dummy? May test it without the hole to see if the mic is sensitive enough to avoid cutting.
That's the weekend project...along with a new headlight switch, and a clay bar and wax.
Old Apr 26, 2019 | 11:01 PM
Rico.Adams's Avatar
5 Year Member
Sure test it first but I think you'll be to far away from it as the dummy is like a box, its an easy job to do take you no more than 5 min to remove it drill it pop the mic into it & pop it back on, oh they only fit in one way so find the 2 lugs first & push it back in ...
Old Apr 28, 2019 | 02:07 PM
flyer39's Avatar
All done. I chickened out on drilling the hole, so the mic stands out from the driver’s side of the overhead. No problem concealing the wire all the way around and into the glove box. Very happy with the Grom. Thanks.
Old Apr 28, 2019 | 02:26 PM
Rico.Adams's Avatar
5 Year Member
Cool, happy to help ...
Old May 11, 2019 | 12:56 PM
Rico.Adams's Avatar
5 Year Member
Just to show that its an easy task to counsel the after market microphone, swop over the dummy for the stock microphone which ever side your drivers seat is ...
Old May 11, 2019 | 03:36 PM
flyer39's Avatar
Excellent!
Old May 11, 2019 | 03:44 PM
Rico.Adams's Avatar
5 Year Member
Excellent!
Thank you ...
ManualofCourse
Jul 19, 2016 06:26 AM
GIjbop
Oct 20, 2009 11:10 AM
BigJ997
Jan 19, 2007 02:49 PM
RCH
Oct 27, 2004 12:06 PM
