Sorry I missed your message last night. Please be patient with me, I'm not mechanically savvy. If it's okay with you, I will call you later today after 5:00 PM.
Thank you.
Hello @Joey1021 ,
It was great talking with you tonight !
Good luck with the KESSY, fingers crossed.
As we discussed, depending on the water level above the carpet, this is the front body control module and relays located on the passenger side front floorboard up on the angle at the firewall.
Also some pictures of the circuit breakers/thermo fuses on the drivers side next to the KESSY module.
@Joey1021 ,
Sorry about the previous pictures, they came out worse than I thought they would, I took a picture of my pictures... I will see if I can replace from that laptop.
But,, just wanted to clarify that the body control module and the relays are located inside of this box on the passenger side as previous stated..
I am having a similar no crank problem with my 04 GT , everything powers up but I get know cracking when turning the key. It has been about a month since I started the car last. I had the main batttery on a trickle charger, but the battery only showed 11.2volts and 3.4 under load. The start battery shows 12.8 volts and 12.4 under load. So I replaced the house battery per the recommended procedure and still have the same issue. My next step is to check the Kessy module. This is a LHD vehicle. I just want to confirm the module is under the carpet on the driver side. To access it do I have to remove the drivers seat and carpet?
