Mangled key 2008 FS
Old Mar 1, 2020 | 08:43 PM
Mr8888's Avatar
Mr8888 is infamous around these parts
Mangled key 2008 FS
Someone tried to destroy my key. Damaging and removing the lock and trunk buttons. The actual Electronic buttons behind the rubber solder broke off. Rubber is all mangled too
Metal key works fine and car recognizes key and push button start still works.
i am getting a key icon in the middle lcd, anyone know what that is.
is my only option the dealer?
can i get the pin code with this
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F16 3829057028
and reprogram a key from ebay with vcds and the pin? Or can i order fresh / blank keys to program from some place
Old Mar 2, 2020 | 08:49 AM
Samhain's Avatar
Samhain is infamous around these parts
Key icon prob indicates low keyfob battery.
Old Mar 7, 2020 | 06:08 PM
Mr8888's Avatar
I bought the vag-key device and blank uncut keyless go key from ebay. Will let you guys know how it goes!
Old Mar 8, 2020 | 12:05 PM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
Who do you suspect did this and why?
There are sources on the interwebs where you can buy after market remote fobs.
Old Mar 8, 2020 | 01:05 PM
Mr8888's Avatar
I know who did it and the why unfortunately. I bought an aftermarket unprogrammed key fob on ebay. I also bought the vagkey to get the pin code and I will use VCDS to try and assign it to the kessy.
I will let you guys know how it turns out.
Old Mar 10, 2020 | 05:06 PM
British's Avatar
Gone, But Not Forgotten.
British has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud of
I'm curious, too. New keys (come in pairs) cost $1,000 at the dealer.
So far, with all my research, I have not found a secondary/non-dealer supplier that works on the Bentley. I guess they really and truly didn't want their cars stolen.
robkat
Sep 26, 2019 03:34 PM
belton
Bentley
10
Mar 22, 2018 11:43 AM
DirtyVegas
Cayenne 955/957
Aug 19, 2015 12:39 PM
mziegler38
Oct 29, 2013 02:17 PM
porsche-driver
Apr 7, 2012 05:10 PM
