Please help 07 Bentley GTC electrical issues
Old Jun 7, 2020 | 09:28 PM
Boywonder007's Avatar
Boywonder007 is infamous around these parts
I purchased a 07 Bentley GTC about six months ago. When I bought the car it only came with valet key. Went to Bentley and got a new set of keys. After I picked up the car, I was not able to open trunk from inside of the car or by pushing the B. I can only open trunk with key remote. Yesterday I went in the car and the car starts to go crazy. Radio come on and off, the top wouldn’t go down. All the lights are flickering on and off. Now the top won’t come back up, I can’t open trunk with the remote anyone. Headlights and tail lights are off. Can someone please help me.
Old Jun 8, 2020 | 11:31 AM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Start with the batteries. Make sure they are good.
Low voltage will make these cars have you cussing and ready to shoot it.
Old Jun 8, 2020 | 11:45 AM
Samhain's Avatar
Samhain is infamous around these parts
But then when you replace the battery and the car magically clears its own faults and everything is perfect again you forgive it.
Old Jun 8, 2020 | 12:26 PM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
Is it on a trickle charger ?
Is it parked indoors out of rain ?
Have you done any drain maintenance?
Old Jun 8, 2020 | 07:18 PM
The car is park outside and it did rain the last two days. Can the rain affect the car and no I haven’t done any drain maintenance on the car.
Old Jun 9, 2020 | 05:00 AM
Ok .
Trickle charge is a must ....check out solar panel chargers if mains power is unavailable.
Handy for airports btw .
Feels like primarily a LHS battery weakness
Water ingress on the micro switch hood wiring is gonna happen inevitably with a cab parked out side permanently....more so if on a gradient as water will run into places it did not when new or in a car wash as they are flat surfaces so it passes .
Age means seals are not as good as when new etc ....hence an inevitably with a not brand new cab .
Anyhow as far as the other water ingress and general drain stuff ........useful in the UK climate here .......
https://www.6speedonline.com/forums/...enance-gt.html
https://www.6speedonline.com/forums/...-part-2-a.html
Old Jun 9, 2020 | 12:04 PM
Hey, thank you for the reply. I went to the car this morning and it wouldn’t start.
Old Jun 9, 2020 | 03:10 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
Perhaps take the advice.
jtec963
New Member Introductions
Nov 20, 2019 06:20 AM
