FS2015 - Front Suspension Dropping (only on extreme turns)
Old Feb 14, 2021 | 06:24 AM
pupdogg's Avatar
pupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud of
Hi Guys, I have a 2015 Flying Spur with approx. 87k miles and recently replaced both the FRONT air struts along with upper control arms. For the struts, I used brand new Arnott AS-3127 and AS-3128 (purchased from a local distributor - https://alleuro.com). After replacing, I test drove the car and the ride seemed just fine. I was able to go over potholes and bumps with no issues as well. However, whenever I make any extreme turns where the steering wheel is all the way to one side (specifically LEFT), the suspension drops. I am able to rectify the issue by straightening the steering wheel column and letting the air fill back up. I have also verified that there are no leaks in the system as after I left the car in HIGH position for approx. 2-3 weeks and it maintained that height perfectly. Does anyone have any thoughts on what might be the culprit? Any help would be greatly appreciated. Thank you!
bahaaqadan
Jan 18, 2022 08:19 PM
pupdogg
Bentley
11
Jun 27, 2021 05:41 PM
Nikita4Ever
Mar 11, 2020 11:40 PM
aquatone
Jan 27, 2019 08:22 AM
phil612
Aug 13, 2017 06:29 AM
