Bentley Tire Pressue Monitoring
Old Mar 21, 2021 | 09:50 AM
tteplitzmd's Avatar
5 Year Member
tteplitzmd is infamous around these parts
Does anyone know how accurate the Tire Pressure Monitoring System is? It's a few pounds off from my manual tire gauge.
Also, the system is recommending pressures well below the pressures recommended on the driver's side label.
I've got 21 inch wheels with the usual Pirelli summer tires.
Old Mar 21, 2021 | 10:37 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
With one of the systems you can set the desired pressures. I know mine gives options for pressure and wheel size. No idea how accurate the sensors are compared to some baseline. Part of the question must be 'how accurate is your manual gauge?'
C
Old Mar 21, 2021 | 11:10 AM
tteplitzmd's Avatar
5 Year Member
Thanks.
The pressures listed on the label seem quite high, 48 and 46 psi. If my manual gauge is accurate, why mess with the electronic sensor numbers?
I have 21` inch wheels, which were supplied when the car left the factory. It seems like most of the guidance is follow the car label for cold pressures.
Any thoughts?
Old Mar 21, 2021 | 12:30 PM
tteplitzmd's Avatar
5 Year Member
My tire pressure label
Old Mar 21, 2021 | 01:44 PM
CatmanV2's Avatar
5 Year Member
For sure I'd stick with the numbers on the label but some people prefer something different (different ride, or track day...)
The recommended pressures on mine are a chunk higher than any other car I've owned, but it *is* a big, heavy car. I'd check the system set up and maybe get a good quality gauge.
I think the other system will be one that you inflate to your preferred pressure, then you go through a calibration process which sets your base pressure (with a temperature compensation) and then it works on acceptable pressure difference, temperature compensated (or at least that's what the Maseratis did)
C
Old Mar 21, 2021 | 02:50 PM
tteplitzmd's Avatar
5 Year Member
Thanks, yeah I've got a good gauge, so I think I'll go with the 48 psi.
I've forgotten my college physics, but I assume the larger tire size has something to do with the higher pressure guidelines.
Old Mar 22, 2021 | 01:00 AM
CatmanV2's Avatar
5 Year Member
Pass. Not sure why as p1xv1xt1=p2xv2xt2
My Granturismo had 20" wheels (as did my Jag actually) and the pressures where nothing like these. But the cars were rather lighter. I think that's the kicker.
C
Old Mar 22, 2021 | 06:11 AM
tteplitzmd's Avatar
5 Year Member
Must be the weight.
tteplitzmd
Bentley
Feb 21, 2021 03:36 PM
Randy V
Bentley
Oct 10, 2019 11:29 AM
ek1
Bentley
Jun 30, 2015 04:42 AM
rdsrllc
Bentley
Oct 8, 2014 01:41 PM
bellemarc
Cayenne 958
Jun 25, 2014 08:38 PM
