Hi all, I have a 2015 Flying Spur and i want to remove the B emblem on the front grille, I know it is only held in by 2 nuts but cannot access the panel, any help would be appreciated. Tried removing the plastic trim panel when the hood is opened behind the grille but does not seem to move.
The older models the grille used to lift with the hood but no the ones and the access seems much harder. Emblem I want to remove Tried removing the plastic trim behind, removed all star screws but not moving Tried removing the plastic trim behind, removed all star screws but not moving
The wings and the center “B” are both self stick and separate pieces. The wings are pricey but the B is about $40.
Hi Ret09gt, thank you for the reply, the replacement piece I
am putting on requires me to get to the back of the grille, see photos attached. Do you know how I get to the underneath to tighten the screws. The locating holes are already in the grille.
