FS2014 - Check Engine Light (intermittent)
Old Jun 15, 2021 | 05:48 AM
pupdogg's Avatar
pupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud of
Getting Check Engine Light (CEL) whenever the weather outside is 55F or higher. Car seems to be running just fine. I clear the DTCs via VCDS and the light doesn’t come on as long as it’s nice and cold outside. In warmer weather, the Light does not come on the first time I start the car after clearing DTCs in standby mode. However, when I turn it off and back on again, it comes on right away.
I understand it can be multiple things but just trying to see if anyone knows which component could be effected by the outside ambient temp the most?
As for an exact code from VCDS, whenever there’s a light, I get Engine cannot be Reached in both standby and running mode of the car with the key in ignition. I also ensured that the Force Engine option was not checked as per RossTech.
Old Jun 15, 2021 | 09:41 AM
Johnny Hotspur GT's Avatar
Administrator
What happens if you try to scan engine #2 ?
Johnny
Old Jun 16, 2021 | 05:51 AM
pwc6t3's Avatar
pwc6t3 is infamous around these parts
You state you are scanning the "car with the key in ignition". Based on your exact wording it sounds like you haven't turned the key. Just having it in the ignition is not enough. Turn the key but don't start the car, then scan.
Old Jun 16, 2021 | 06:38 AM
pupdogg's Avatar
Engine #2 shows STATUS: OK but is also listed as Cannot be Reached. See attached.
To clarify, I've tried with key in ignition in both standby (key in ignition with single turn until all electronics turn on)and running mode (key in ignition with full turn to run the car).
Old Jun 27, 2021 | 05:19 PM
Administrator
@pupdogg ,
What was the outcome here ?
Johnny
Old Jun 27, 2021 | 05:26 PM
pupdogg's Avatar
I originally thought the check engine light might’ve been a side effect of this: https://www.6speedonline.com/forums/bentley/445347-fs2014-epc-light-issue.html#post4879473. So I patched the vent hose and was back up and running. However, the Check Engine light is still there and whenever I’d reset it on cold day, it remained good but as soon as nice hot day came around, it would come up on the 2nd start of the day right at startup. I called the dealership to schedule me in for error code and they were swamped at the time and I was most likely going to be looked at this week. The cars been running just fine and the dealership tech said that as long as you’re not exhibiting shaking of the car while idle, you can drive it.
acmf74
Oct 20, 2017 05:41 PM
bebeqq1231
Mar 23, 2017 08:54 AM
'97 993 C4S Inv
993
Apr 9, 2009 08:42 AM
Itzkirb
Aug 9, 2005 04:30 PM
