Steering lock won't engage using STOP button
Old Oct 11, 2021 | 02:46 PM
pupdogg's Avatar
pupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud of
Vehicle: 2015 Flying Spur W12
I'm experiencing a very odd issue. Whenever I turn the car off using the Start/Stop button, I no longer hear the steering lock engage and then when I open the door, the dash tells me "to engage steering lock, press and hold the stop button". However, this is not the case when I use the physical key in the ignition to do the same. With key in the ignition, the steering lock engages (when key is taken out) and disengages (when key is inserted) as expected. With key in my pocket, the steering lock only disengages when starting the vehicle but does not engage when turning it off. Any ideas?
Old Oct 11, 2021 | 07:29 PM
tteplitzmd's Avatar
5 Year Member
tteplitzmd is infamous around these parts
steering lock
My 2013 GTC behaves the same. I don't really see it as a problem. I suspect there is no defect. There are other quirks like this, for example I can't retract the side mirrors when the car is in motion, and I simply assume it's a safety issue and part of the intended design.
Old Oct 12, 2021 | 09:04 AM
pupdogg's Avatar
Thanks @tteplitzmd . For anyone else reviewing this thread, please see my most recent diagnostic scan below. ACC/Start Auth module shows 1x fault code: 00576 - Terminal 15 - 006 - Short to Plus - Intermittent
Code:
Tuesday,12,October,2021,09:38:58:32422
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
Chassis Type: ZA-BY62 (6N0)
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
23-Brake Booster -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
48-Seat, Rear, DS -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5D-Operations -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
66-Seat, Rear -- Status: OK 0000
68-Wiper Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
71-Battery Charger -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
7F-Inform. Electr. II -- Status: Cannot be reached 1100
Address 01: Engine (J623-CKHF) Labels: None
Part No SW: 07C 906 023 K HW: 07C 907 309
Component: ME17.1.6 H16 6514
Revision: MHH16--- Serial number: VWX3Z0M7012687
Coding: 0D2A0032436E00020001
3 Faults Found:
16672 - Please Check DTC Memory of ECU Number 2
P1923 00 [047] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Date: 2021.10.09
Time: 18:10:42
Engine RPM: 587.00 /min
Normed load value: 12.9 %
Vehicle speed: 0 km/h
Coolant temperature: 96 °C
Intake air temperature: 65 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.536 V
Unlearning counter according OBD: 40
10203 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear
18909 - ROD - Unknown Error Code
- 00 [032]
Readiness: 0000 0001
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 4W0 927 158 A HW: 0CU 927 760 A
Component: OBL 60 MPIUSA H16 0005
Revision: --H16--- Serial number: VWX3Z0M7012687
Coding: 000002
1 Fault Found:
18167 - Brake Switch (F)
P0703 00 [040] - Electrical Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.10.11
Time: 13:35:18
Voltage terminal 30: 14.404 V
Engine RPM: 591 /min
Status electric parking lock holder solenoid-Desired State Solenoid Out 10: OFF
Status electric parking lock holder solenoid-Desired State Solenoid Out 11: OFF
Status electric parking lock holder solenoid-Desired State Solenoid Out 12: OFF
Status electric parking lock holder solenoid-Desired State Solenoid Out 13: On
Status electric parking lock holder solenoid-Desired State Solenoid Out 14: OFF
Status of brake signals-Brake lamp switch: Not operated
Status of brake signals-Brake pressure switch: operated
Status of brake signals-Validity of brake pressure information: valid
Status of brake signals-Validity of brake pedal information: invalid
Status of selector lever lock: active
Status data bus communication diagnostic interface-State ACC_Radar received: not received
Status data bus communication diagnostic interface-State Airbag received: not received
Status data bus communication diagnostic interface-State BATMAN received: received
Status data bus communication diagnostic interface-State Deashboard received: not received
Status data bus communication diagnostic interface-State ECM received: not received
Status data bus communication diagnostic interface-State ESP received: not received
Status data bus communication diagnostic interface-State EZS received: received
Status data bus communication diagnostic interface-State Gateway received: not received
Status data bus communication diagnostic interface-State NIVEAU received: not received
Status data bus communication diagnostic interface-State Parking Brake received: received
Status data bus communication diagnostic interface-State Steering Angle received: received
Status data bus communication diagnostic interface-State Steering Assist received: not received
Transfer speed by dash panel insert: 0.00 km/h
Transfer speed by dash panel insert: valid
Address 03: ABS Brakes Labels: None
Part No SW: 4W0 614 517 A HW: 4W0 614 517 A
Component: ESP 8.1 4WD H01 1100
Revision: 00000000 Serial number: 00000000000000
Coding: 0002543
3 Faults Found:
01315 - Transmission Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0280
Hex Value: 0x0013
Hex Value: 0x449D
Hex Value: 0x0000
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0280
Hex Value: 0x0013
Hex Value: 0x299D
Hex Value: 0x0000
01314 - Engine Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0280
Hex Value: 0x0013
Hex Value: 0x889D
Hex Value: 0x0000
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 G HW: 3D0 909 137 G
Component: C0 Kessy 6850
Revision: 00H24072 Serial number: VWX3Z0M7012687
Coding: 0405741
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 2141
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 174
Time Indication: 0
Date: 2021.10.11
Time: 08:42:02
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4W0 959 760 HW: 4W0 959 760
Component: MEM-BFS H04 0600
Revision: AA000000 Serial number: 00000075013650
Coding: D0081F0085070090090001010101002100012727000000
No fault code found.
Address 07: Control Head Labels: 3D0-907-048.clb
Part No SW: 3D0 907 048 HW: 3D0 907 048
Component: J127 KBT vorn 0100
Revision: ABH15001 Serial number: VWZ6Z7N0273035
Shop #: WSC 00000 000 00000
VCID: 63C5AB20A62B1E93BE-8036
Address 08: Auto HVAC Labels: None
Part No: 3W5 907 040 J
Component: Climatronic BY621 3029
Coding: 0000101
Shop #: WSC 00083 790 00151
VCID: 3D713D58600F0863E8-8068
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 Q HW: 3D0 937 049 Q
Component: J519 7700
Revision: -4007--- Serial number: --------------
Coding: 40820000AB2A11C02508030000000000
2 Faults Found:
00576 - Terminal 15
00978 - Lamp for Low Beam; Left (M29)
006 - Short to Plus
Address 11: Engine II (J624) Labels: None
2 Faults Found:
12646 - Random/Multiple Cylinder Misfire Detected
P0300 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.10.09
Time: 18:09:20
Engine RPM: 550.00 /min
Normed load value: 14.9 %
Coolant temperature: 94 °C
Intake air temperature: 69 °C
Voltage terminal 30: 14.371 V
Unlearning counter according OBD: 38
18909 - Cylinder 10
P0310 00 [032] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.10.09
Time: 18:10:42
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4W0 907 567 HW: 4W0 907 567
Component: AC201 NAR BY681 00931
Revision: 00041000 Serial number: 00000000603176
Coding: 0020681
Address 15: Airbags Labels: None
Part No SW: 3W3 959 655 HW: 3W3 959 655
Component: 27 Airbag 9.43 H04 0050
Revision: 93H04005 Serial number: 003FV000H1VC
Coding: 0012855
Subsystem 1 - Part No: 4W0 959 339
Component: BF-Gewichtsens. H03 0102
Subsystem 2 - Serial number: 02CUP
Subsystem 3 - Serial number: 6332DRB40F3AC997
Subsystem 4 - Serial number: 6342DRB40F33CE28
Subsystem 5 - Serial number: 63528RB406FEB07A
Subsystem 6 - Serial number: 63628RB406FEB083
Subsystem 7 - Serial number: 63747RB407032FD9
Subsystem 8 - Serial number: 63847RB407032F41
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2021.08.25
Time: 14:44:18
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000042
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No SW: 3W0 920 851 L HW: 3W0 920 851 L
Component: J285 KOMBI-INST. 3925
Revision: KPH10V02
Coding: 0034214
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3W0 920 851 L
Component: J533 GW-K-CAN TP20 3925
Coding: DFFBFFFFEBD51702
1 Fault Found:
03163 - Control Module for Information Electronics 2
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Time Indication: 0
Date: 2021.10.09
Time: 14:52:49
Address 23: Brake Booster Labels: None
Part No: 3W0 907 563 B
Component: BREMSBOOSTER 007 0430
Revision: 00007000 Serial number: 00000000027683
Address 28: HVAC, Rear (J524) Labels: None
Part No SW: 4W0 035 008 HW: 4W0 035 008
Component: CLIMATE ECU H06 0062
Revision: P1H06004 Serial number: 51300129144001
Coding: 00000200010102
Subsystem 1 - Part No SW: 4W0 907 042 A HW: 4W0 907 042
Component: RBM-BY621 H09 0055
Serial number: WA106054000004616352
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 200
Time Indication: 0
Date: 2021.03.13
Time: 12:14:09
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 4W0 035 342 HW: 4W0 035 342
Component: SG EXT.PLAYER H13 0243
Revision: A1001003 Serial number: 7662381930
Coding: 030000
Address 34: Level Control Labels: None
Part No: 4W0 907 553
Component: LUFTFDR.-CDC- 3C3V0 7705
Coding: 0005541
4 Faults Found:
00456 - Control Module for Access and Start Control (J518)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
00062 - Suspension Function Request
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H04 0600
Revision: AA000000 Serial number: 00000075587113
Coding: D0081F0085870090090001010101012100012727000000
3 Faults Found:
03766 - Motor for Seat Belt Height Adjustment
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 144
Time Indication: 0
Date: 2020.11.17
Time: 09:39:07
Freeze Frame:
Fault Status: 01101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Time Indication: 0
Date: 2021.06.05
Time: 07:49:39
04109 - Switch for Seat A/C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 90
Time Indication: 0
Date: 2021.10.11
Time: 09:58:37
Address 37: Navigation (J0506) Labels: None
Part No SW: 3W0 035 017 L HW: 3W0 035 017 L
Component: RNS-MID H15 0520
Revision: AB001001 Serial number: VWZ6Z7N0273035
Coding: 06010002000000044000
Subsystem 1 - Part No: 3W0 919 859 BN
Component: NAR V4 7963
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 27
Reset counter: 51
Time Indication: 0
Date: 2021.10.09
Time: 17:32:59
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 H
Component: Dachmodul 0910
Coding: 0020493
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 4W0 959 794
Component: TSG HR D26
Coding: 0000040
Subsystem 1 - Part No: 4W0 959 107 A
Component: 11 HDSG 0806
Subsystem 2 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
5 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
00576 - Terminal 15
00120 - Outside Warning Light/Door exit Light Driver Side
012 - Electrical Fault in Circuit
00121 - Outside Warning Light/Door exit Light Passenger Side
00318 - Supply Voltage for Rear Lid Control Module
001 - Upper Limit Exceeded - Intermittent
Address 47: Sound System Labels: None
Part No SW: 4W0 035 465 HW: 4W0 035 465
Component: DSP 10 Kanal 0010
Revision: 00H07001 Serial number: 75824010506603
Address 48: Seat, Rear, DS
Cannot be reached
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 H HW: 3W0 907 801 H
Component: EPB BC7H0300 HC7 0300
Coding: 0022513
5 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
02443 - Control Head
Address 56: Radio (J0506) Labels: None
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 27
Reset counter: 51
Time Indication: 0
Date: 2021.10.09
Time: 17:32:59
Address 5D: Operations
Cannot be reached
Address 65: Tire Pressure Labels: None
Part No SW: 3W7 907 273 C HW: 3W7 907 273 C
Component: J0502 RDK 0006
Revision: 0004 006 Serial number: 00000700004851
Coding: 0000E03175CA4286EB75B9FD52EB0097FC004B6E4B6E4B6E4B6E4B64
Address 66: Seat, Rear (J877) Labels: None
Component: MEM-BFS-Fond H04 0600
Revision: AA000000 Serial number: 00000075692368
Coding: C0081E8085810000090021000001000000002727000000
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W5 955 023 M
Component: Wischermodul ª0401
4 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
00459 - Control Module for Display and Input; Front (J523)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 6C: Back-up Cam. Labels: None
Part No SW: 4W0 907 441 HW: 4W0 907 441
Component: J772__Rearview 0030
Revision: 00H12000 Serial number: 525 PA8J390083
Coding: 2020003
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4W0 959 107 A HW: 4W0 959 107 A
Component: HDSG-ModulH04 0806
Revision: 00000000 Serial number: 275300199
Coding: 170206C120
No ASAM data for: "EV_HDSGBY6" (BY62)
1 Fault Found:
0013 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 91
Date: 2000.00.00
Time: 00:00:00
Address 71: Battery Charger (J367) Labels:* None
Part No SW: 3W3 915 181 B HW: 3W3 915 181 B
Component: EMM Batt Man H05 0570
Serial number: 0000000001
Coding: 5E0100
Battery Monitoring Control Module:
1 Fault Found:
13634304 - Invalid Data Received from Control Module for Access/Start Authorization
U100B 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 91
Date: 2021.10.11
Time: 16:15:27
Address 76: Park Assist Labels: 3W0-919-283-V3.clb
Part No SW: 3W0 919 283 G HW: 3W0 919 283 E
Component: J446 ST Parkhilfe 0111
Revision: 11H02001 Serial number: 58131323800136
Coding: 0300066
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3D0 035 730 B HW: 3D0 035 730 B
Component: Telefon 012 0825
Revision: -------- Serial number: 35909603572971
Coding: 020106010100010000000000
1 Fault Found:
13893888 - Function Restricted due to Excessive Voltage
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 91
Date: 2021.10.11
Time: 12:56:49
Address 7F: Inform. Electr. II
Cannot be reached
Old Oct 12, 2021 | 04:28 PM
Johnny Hotspur GT's Avatar
Administrator
Hello @pupdogg ,
First off, thank you so much for putting your full scan in a scroll box, much appreciated ! 😀
As to your fault, have you cleared it, does it return immediately after clearing, did you have any water infiltration, such as the KESSY module getting wet, any other issues before this fault ?
Johnny
Old Oct 13, 2021 | 09:44 AM
pupdogg's Avatar
Hi @Johnny Hotspur GT , I hope you're well! Yes, I did clear and still nothing. Not sure if you remember but earlier this year I thought I had an issue with the Steering Column Lock Actuator (this post: https://bit.ly/3yDTX9h) and went about taking apart the actuator and verifying it's motor, relays and microswitches worked as expected. In the end, I discovered that the there was no issue with the actuator itself and it originated from me going about my normal day, turning the car off via the Stop button, and then proceeding to exit/locking the vehicle. When I exited, there must've been a message stating "to engage steering lock, press and hold the stop button" but I did not notice it at that time. So, when the next time I went to go turn ON the vehicle, the steering lock was already disengaged and no matter what I tried, the vehicle wouldn't even wake up the dash or turn ON. I rectified this situation after 2 weeks of banging my head against the wall and realizing that if I simply take out the actuator and force/fake lock it by giving its motor 12VDC and then reinsert it back into the steering column that the car would think everything is fine and wake up/turn ON...which it did! Since then, I've been turning the car ON via the Start/Stop button and then turning it OFF using the actual key (which causes the steering lock to actuate). It's a little frustrating not knowing what's causing this to happen.
I tried to Google similar behavior with Audis/VWs and did find another user experiencing the same issue but his forum thread did not post a resolution (here's his thread: https://bit.ly/30iuZ37). So I'm not sure how he got it fixed. Any common sense ideas would be great help as I know you did end up genetically rebuilding your car
Old Oct 14, 2021 | 09:17 AM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
I have an 06 and I don’t think it ever locked. I only use the push to start button.
Old Oct 14, 2021 | 12:55 PM
sam08861's Avatar
5 Year Member
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
My 06 works the same way.
I found it will click/lock if you try and turn the steering wheel a tiny bit after pressing stop.
Old Oct 17, 2021 | 05:02 PM
tteplitzmd's Avatar
5 Year Member
steering wheel lock
I took out the manual. The short answer is when using the start/stop button in lieu of the key, you must lightly press the start/stop button and the steering wheel audibly locks (at least mine does).
When you use the key, upon removal of the key the steering wheel locks. So, in my opinion, as I get the same message you cited, I don't think there's an error.
If you can't get the steering wheel to lock with the manual light touch to the start/stop button, then I've misunderstood your situation.
Sker66
Sep 28, 2017 11:01 AM
ewu64
Apr 17, 2012 07:34 PM
jyupitt1
Sep 5, 2011 10:32 PM
ccmagic
Jun 20, 2009 12:20 AM
BigMac78
Oct 27, 2007 07:47 PM
