Air suspension leak detection
Old Oct 30, 2021 | 01:37 PM
Linescreamer's Avatar
Linescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud of
As a follow up to my front strut leak detection project. .. I have spayed all the lines at the compressor and the tops of both front struts and the left front strut completely. I have no bubbling. I did get a quarter turn on all the air lines at the head of the compressor. My car drops 2-3 inches during a 7 day period if left untouched in the garage. If left in Jack Mode for the same amount of time the front left will be significantly lower than the rest. Any ideas on where to go from here?
Old Oct 31, 2021 | 09:09 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
In addition to other troubleshooting login to address 34, I believe this is the suspension level controller in vcds. Perform the output tests. The tests will go through different operations of the air suspension. One test runs the compressor and checks the pressure reservoir if it achieves the proper level.
Unfortunately reading through old threads, to my knowledge no one has ever come back and explained the solution to the mysterious sinking suspension problem when all else appears normal.
Old Oct 31, 2021 | 09:29 AM
Samhain's Avatar
Samhain is infamous around these parts
All the cars will sink eventually, not as fast the OP guy's car usually. There's a Phaeton on display (or was) at the Dresden glass factory where they are made. Visitors report that this car is usually in some state of suspension drop and they have to start it every once in a while to keep the suspension pumped up. And that's at the factory.
Old Nov 1, 2021 | 11:35 AM
Originally Posted by Dark Green
Obviously the fact that the air suspension tries to keep the car level for seven days after shutdown, means that to avoid damaging the pump you would have to select Jack Mode whenever the stopcock was closed.
Are you saying that the compressor is kicking on when the car is off to keep the suspension full of air?
I do think the idea to isolate which leg of the system is leaking makes a lot of sense. Thanks
Old Nov 1, 2021 | 12:07 PM
I see. Where is the accumulator? Is it the egg shaped thing attached to the shock?
Old Nov 1, 2021 | 12:17 PM
Oh wow. Where is that located? I didn't bother tracing all the lines looking for leaks because I don't think it's possible for a line to leak that slowly.
Old Nov 1, 2021 | 01:13 PM
So it's under the left rear seat in front of the rear wheel?
Old Nov 8, 2021 | 11:35 AM
Is it possible that these shocks will only leak when under a load? Has anyone not found a leak in a shock until they put it under a load with tires on the ground? I have checked the suspected shock only with the wheel off.
RI-PANTT
Aug 2, 2021 01:11 PM
gregwarner
Bentley
Jan 9, 2019 10:29 AM
panamera_lou
Jul 23, 2018 10:04 AM
panamera_lou
May 19, 2018 05:01 PM
phil612
Aug 13, 2017 06:29 AM
