PTT leaking air strut
Old Jul 12, 2021 | 08:27 PM
RI-PANTT's Avatar
RI-PANTT is infamous around these parts
found my PTT sagging over night and found a leak drivers front in the upper strut mount there the sensor clips on. i read about so good and bad on suncore, RMT but not much about arnott. im looking to do the work my self. just rather get something good i can get a arnott for about 1200 left front.
Old Jul 13, 2021 | 04:32 AM
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
Arnott are generally considered very good.
Old Jul 16, 2021 | 07:47 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
I got an Arnott new unit from Rock Auto, said to have a new Eibach strut. Loving it so far....
Old Jul 19, 2021 | 04:57 PM
jzchen's Avatar
5 Year Member
Wanted to clarify something. At first when I replaced the front left strut only, I could feel a difference between the damping front left and old (~49k mi) front right strut. I noted this to someone on here as a possible concern. After driving around some months the difference has disappeared and I feel no difference front left and front right, hence the happiness remark...
Old Jul 20, 2021 | 02:53 PM
Nikita4Ever's Avatar
Nikita4Ever is infamous around these parts
I purchased Porsche strut for $1500 with two years warranty.
Old Jul 20, 2021 | 04:53 PM
riden's Avatar
riden has a spectacular aura aboutriden has a spectacular aura aboutriden has a spectacular aura about
Was that a preassembled unit? I thought they only sold certain components then you had to assemble and use some parts from the old strut.
Old Jul 23, 2021 | 08:47 PM
jzchen's Avatar
5 Year Member
For a fully new unit with lifetime warranty Arnott is hard to beat. The unit was more substantial (heavier) than the old OEM one I pulled off.
Old Aug 1, 2021 | 11:39 AM
ciaka's Avatar
Whatever shocks you replace with, I am sure they will be fine as long as you make sure connections are air tight and dont leak over time. Excessive leak leads to air compressor failure over time.
I have DIYs for the air suspension along with lots of info, in case you want to DIY.
Good luck.
Old Aug 1, 2021 | 11:41 AM
RI-PANTT's Avatar
i just replaced it with a new Arnott. works great. also found my rattling noise overs bumps it was sway back bushings
Old Aug 2, 2021 | 10:13 AM
rog2961's Avatar
rog2961 is infamous around these parts
Rmts leaked within a year. Replaced with arnotts, can't beat the lifetime warranty.
Old Aug 2, 2021 | 01:11 PM
shrike071's Avatar
Classic case of "the poor man pays twice"
PrestigeLdn
Bentley
24
Oct 13, 2021 03:20 AM
KamanCali
Sep 20, 2021 04:01 PM
shorttough
Bentley
Sep 9, 2020 05:29 PM
gregwarner
Bentley
Jan 9, 2019 10:29 AM
phil612
Aug 13, 2017 06:29 AM
