Shift indicator in display erratic
Old Aug 1, 2023 | 08:07 AM
FLMansory's Avatar
FLMansory is infamous around these parts
2006 Continental gt-the indicator in the dash display reads correctly until I go to D. Then all the indicators light up-P R N D S. They stay that way until I shut the vehicle off. The manual shift by the shifter or paddles will not work when this happens. Has anyone had this issue? I thought it was the shifter dust cover because it has magnets in that slide on the board; because it was broken - but that did not help. The trans is not in limp mode. Could it be the eBay item?Thx
Old Aug 1, 2023 | 10:50 AM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
When I replaced mine I had the same problem. It turned out the magnet had not been inserted correctly at the factory - and it was a genuine VAG part!
Start by checking that and then the circuit board would be the next step.
See post #17 on this thread: https://www.6speedonline.com/forums/...e-wants-2.html
Old Aug 1, 2023 | 11:11 AM
FLMansory's Avatar
Thanks for the tip-I remember seeing the magnet flat side down but Im gonna pull it back out and check it . Mine was not a VAG part so Im gonna make sure they are magnets also.
Old Aug 1, 2023 | 11:24 AM
BruceR's Avatar
5 Year Member
You mention "flat side down" rather than "up" which leads me to ask if you installed the cover correctly with the smooth side UP, ribbed side down?
Old Aug 1, 2023 | 11:29 AM
FLMansory's Avatar
Yes smooth side showing in shifter hole-i was talking about the magnet flat side being up to ride on circuit board
Old Aug 1, 2023 | 02:03 PM
BruceR's Avatar
5 Year Member
I figured as much but just wanted to clarify. Maybe try a can of Dust Off to blow away any dirt? Maybe the circuit board is misaligned? Just some things to look at.
Old Aug 1, 2023 | 02:57 PM
FLMansory's Avatar
OK- here is what I found. The magnets are in place correctly and are strong. The circuit board looked OK under magnification. Took off the top plate to check the top of the board looked good. Took Off the plastic white piece on top of the shifter as it looked like it was not sitting flat.
Put it all back together and now it works fine. The only thing I can think of is it needed to be Synchronized ? because the key was on when I did it first..Or maybe it was out of place some to not be aligned properly to the board? Dont know but it works now. Thanks for the insight.
Now on to the AC issues @ highway speeds not cooling on auto
Old Aug 1, 2023 | 04:31 PM
BruceR's Avatar
5 Year Member
Glad you got it working. Sounds like that white piece of plastic might have skewed it a bit. Good luck on the AC. When my '09 had a problem with the AC blend doors not functioning correctly a software reload fixed it. I don't have any details about what was done though.
Old Aug 1, 2023 | 04:54 PM
FLMansory's Avatar
I wonder if my HP tuners software would let me flash it Or My j2534 box and a Bentley subscription? Does anyone know?
ciaka
Cayenne 955/957
Oct 22, 2020 11:46 PM
luva966tt
Aug 30, 2011 09:41 PM
htownbdr
Jul 19, 2010 10:46 PM
adan911
Tech / How To
Dec 6, 2009 10:54 AM
meiwah98
Nov 27, 2005 11:53 PM
