Side Mirror Removal
Old Nov 21, 2023 | 02:18 PM
gerryfh's Avatar
gerryfh is infamous around these parts
Side Mirror Removal
Hi does anyone have any advice on how to remove the drivers side door mirror on a Continental GT, I’ve got the door panel off after hours of work but it looks like I’ll have to remove the window glass to get at the bolts I can’t believe how difficult it has been so far.
any help would be appreciated
Old Nov 23, 2023 | 01:04 AM
xclens's Avatar
5 Year Member
xclens is infamous around these parts
I have removed the mirrors from both sides of my '07 GT to replace the lights underneath.
I cannot find the guide I used for this, but you start with turning your mirror (electronically) either all the way to the outside or all the way to the inside. Then you use a plastic wedge tool (like a small plastic crow bar) to gently pry the mirror out towards you, towards the rear of the car. Use a towel or something similar against the paint of the housing. It will be a little resistance, but it will soon pop out. After the mirror has popped out I believe there are 3 screws to remove the light on the bottom.
I will try to find the guide I used.
Old Nov 23, 2023 | 01:06 AM
xclens's Avatar
5 Year Member
In this thread he says to turn the mirrors IN and UP before attempting to pull the mirror loose.
https://www.6speedonline.com/forums/...-pictures.html
Old Nov 25, 2023 | 07:53 AM
xclens's Avatar
5 Year Member
Ahh.. My bad if I misinterpreted your question.. I tried to answer how to remove the mirror glass from the housing, I now realise you were probably asking how to remove the actual whole mirror casing from the door. I don't know anything about that, but please do send a reply if you figure it out.
REDNOSEGT
Bentley
19
Nov 21, 2023 04:27 PM
fallingjetengine
Nov 4, 2020 09:12 PM
twilight
Cayenne 955/957
Mar 9, 2012 10:27 AM
NickV73
Sep 19, 2011 08:07 AM
