Shipped car to me, no start - help
Old Jun 23, 2025 | 02:04 PM
janaka1's Avatar
janaka1
Good day
I somewhat recently purchased a new to me 2006 Continental GT from BAT.
I had the car shipped across the country (Canada) to me and upon it's arrival to me it was dead.
When they initially tried to unload it rolled over but the batteries gave out, no charge, I came to find out it needed a boost when the transporter who brought it the last leg needed to boost it to get it on the truck.
We installed two new batteries already as a safeguard - we have lights and power, no obvious fuses out, it will not turn over or even click at all.
We have a "steering defective - workshop" coming up with key in.
Any help is appreciated.
Old Jul 9, 2025 | 11:05 AM
Johnny Hotspur GT's Avatar
Administrator
Hello @janaka1 ,
Welcome to 6speedonline !
How did you make out with your no start issue ?
Johnny
Old Jul 9, 2025 | 11:18 AM
janaka's Avatar
janaka is infamous around these parts
Hello @janaka1 ,
Johnny
still no start
we have the steering fault message so we are working to replace/fix the actuator under the steering wheel to see if that will allow us to start it.
replacing the relays on the board first then will just replace the whole mechanism if that doesn’t work.
Old Jul 18, 2025 | 05:34 AM
janaka1's Avatar
janaka1
Red face
July 18th update
I've replaced the relays on the board on the steering lock mechanism. Did not work.
I have now replaced the steering lock mechanism in its entirety and still have no start and steering fault on dash.
We do not have accessory power either, not sure I mentioned that, such as no ability to put up the windows, or disengage the parking brake which is a nuisance as we can't put the car outside at all.
Any ideas or input on where to go next is greatly appreciated.
Sincerely,
Discouraged Bentley owner - Jason
Old Jul 19, 2025 | 10:34 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Originally Posted by janaka1
July 18th update
Sincerely,
Hello ..welcome to the Bentley challenge,
A proper scan with a RossTech VCDS would help. This item is available from RossTech and is not to be confused with the generic obd2 under dash scanners.
There is a Kessey module under the US driver's side carpet. Pull this unit and check for water damage.
An internet search regarding "Bentley Kessey unit wet" and "Ross Tech VCDS" will help move this query along.
E
Old Jul 19, 2025 | 11:37 AM
Administrator
Exclamation
Hello @janaka1 ,
One point of concern is the fact that you replaced the steering column lock/module, what did you replace it with, a used part, or a new part, if new, was it done at the Bentley dealership ?
One can not just replace it with a used part, as the steering lock module, KESSY module, engine ECU'S, must all be matched from the factory, one can try with Ross-Tech VCDS to adapt the used lock module by the adaption process, I did the same when I replaced my original (parts vehicle) steering column, I had all matching parts, but my steering column had play and grinding noise, so I got another from a yard, I did the adaption with RT, but the adaption would only last one start cycle, I ended up cutting the anti-theft shield off on the column in the vehicle, removing the mechanism and unlocking the column by hand, I then plugged my matching lock module board in under the dash.
As far as no power, that would have been my first check point before even touching the steering column lock module, there are many fuses to check, along with all of the mega fuses, even flat bar fuses on the top of the starter battery (right side), be sure to check all mega fuses on the left side house battery enclosure, along with power to all fuses in the driver's side facia fuse box, and the E-box under the hood in the cowl area.
As 1eapplebaum said, a scan is needed for greater details, and not a generic scan, a Ross-Tech VCDS or ODIS VAS 5054 scan.
See attached fuse layout.
Johnny
File Type: pdf
Old Jul 20, 2025 | 06:36 AM
janaka1's Avatar
janaka1
It seems we have turned a corner - we no longer have the 'steering fault' but have the immobilizer notice.
I will share the fuse manual with the tech (non Bentley tech, no Dealership within 12hours of us). I have been assured he's tested them though and no blown fuses.
He has applied power to the starter pole and the engine does turn over, so we know that's working at least.
They do not have either of the scanners listed in the shop but have ordered a scanner for it so we'll see how that progresses. Slow and steady (painful) seems to be the way.
Old Jul 20, 2025 | 06:38 AM
janaka1's Avatar
janaka1
I will have them look at the Kessey but this failure occured post shipment in an enclosed trailer, I can't imagine that's the issue but we will investigate. I have seen this pop up on many searches as well. Thank you.
NigelM
Bentley
24
Jul 12, 2021 04:46 PM
turbo_secret
Bentley
20
Dec 9, 2015 07:00 AM
Mz3bo
Cayenne 955/957
Jan 25, 2010 11:45 AM
exoticalex
Apr 26, 2008 06:29 PM
