Battery Drained
Old Oct 2, 2008 | 10:34 AM
BoxsterofWar's Avatar
BoxsterofWar is infamous around these parts
Exclamation Battery Drained
My old Battery died on me so I figured what the heck let me get a new battery. Well two days later battery was drained again so I returned the battery b/c I had warranty. So I got another battery and had my alternator tested everything was normal. Again 2 days later battery dead. Nothing was left on in the vehicle....I need help if anyone has gone through this let me know what you did to solve it please....Thanks again this forum has helped me out alot in the past....
Old Oct 3, 2008 | 07:11 PM
TTCarrera's Avatar
TTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of light
You're not leaving the key in the ignition overnight, are you?
Old Oct 7, 2008 | 10:54 AM
Bob Z.'s Avatar
Bob Z. is just really niceBob Z. is just really niceBob Z. is just really niceBob Z. is just really nice
If you bought it new from a Porsche dealer check with them - there was a bad batch of batteries that came to the US a while back...maybe you got one.
Also, you can put a meter on the battery - after a couple hours you will see a small current draw, which is normal (to maintain the clock, etc.) - anything more than the norm and you have a problem...your dealer can provide the norm draw numbers.
Also, when you are not using your car be sure to lock it and not leave the key near the car. And a battery maintainer is a sure way to avoid problems, which connects the cig lighter.
Old Oct 7, 2008 | 11:23 AM
Thanks for the info. I am having Vivid Racing checking it out. Status is they think that my secondary air pump is staying on I will keep you all posted....
Thanks again
Old Oct 7, 2008 | 11:31 AM
Bob Z.'s Avatar
I have some specific numbers on the normal current draw at home - I can dig it out tonight if you like.
Old Oct 7, 2008 | 10:48 PM
Dino V's Avatar
Curious to see what was causing your battery to drain.
Old Oct 8, 2008 | 10:51 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
You would hear the pump running if it was staying on, Its pretty loud, especially when the engine is off.
Old Oct 20, 2008 | 03:47 PM
Well after process of elimination it was the alternator. thank god it was just
Old Oct 20, 2008 | 06:14 PM
986S's Avatar
986S is infamous around these parts
Someone mentioned leaving the car locked. I heard that leaving the car unlocked will help save the battery. Anyone know which is true?
Old Oct 22, 2008 | 01:16 PM
Bob Z.'s Avatar
The dealer told me to save the battery, leave the car "locked" and to not leave the key nearby. Also, the car will go into "sleep" mode after a few days and if so, you'll need to unlock the door via the keyhole.
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
ECS Tuning - VW
Sep 30, 2015 12:21 PM
