Condensation on Windshield Problem
Old Mar 5, 2022 | 02:43 PM
ralph1461's Avatar
ralph1461 is infamous around these parts
Having problem with my Boxster and looking for some guidance. Foam starting coming out of the air vents, stopped and now my windshield gets exterior condensation. Very annoying since running around with wipers on all the time. Seems cold air is leading from the defrost, hitting the windshield and causing the fog. I live in Florida where it’s hot and humid so turning down my AC or having it come out of the footwell is not an option.
I’ve looked at all the DIY videos on YouTube talking about the foam problem, but they don’t address my particular problem. Many thanks in advance for any h
Old Mar 7, 2022 | 03:56 AM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
Old Mar 7, 2022 | 06:48 PM
Sammy1931's Avatar
Sammy1931 is infamous around these parts
@ralph1461 you will likely get a lot of different responses and none will address your problem. I know cuz I HAD the same problem with my 987. It's caused by the air conditioner separator vent (inside the HAVC unit) losing the foam covering. Once all the foam is gone, the cold air seeps through the vent and out your defrost vents. Given what has to be bad humidity in Florida, when the cold air hits the windshield it causes condensation. Like you, I looked at all the DIY videos and none solved this problem. Outside of this company I found that solves the problem with a product they produce, the only solution is a major repair that involves taking out the dash the access the HAVC unit. If you are interested in the company, please DM me as don't want to get in trouble with 6Speed.
therron4ou
Bentley
May 16, 2017 07:04 AM
cblanco
Oct 25, 2016 03:56 PM
Jonhunt
Jul 24, 2014 01:41 PM
racerja
Cayenne 955/957
Feb 1, 2012 06:19 PM
Pepper
Cayenne 955/957
Feb 1, 2012 12:38 AM
