Coolant Leaking, How hard to replace?
Old May 12, 2007 | 11:06 PM
fong718's Avatar
fong718 is infamous around these parts
I have coolant leaking in my 986 when the reservoir is filled up, I assume it is cracked/leaking somewhere. Is it hard to do it myself to replace it?
Old May 13, 2007 | 06:05 AM
nyboxsterS's Avatar
nyboxsterS is infamous around these parts
I just checked my Boxster service manual and it looks very easy. Here's what you need to do:
1. Open rear trunk and pull out the oil dip stick. Use needle nose pliers to press together dipstick guide tabs (around where dipstick goes in) and detach guide tube from the engine service tray (the black plastic catch tray).
2. Remove oil filler and coolant reservoir caps. Using a flat head screw driver lever (or pry) off the trim cover underneath the filler necks. This is basically the top cover to the engine service tray.
3. Remove rear trunk floor carpet. Remove trunk trim along front bulkhead (closer to engine bay). You will now be able to clearly see the reservoir tank, coolant level sensor, and coolant reservoir mounting fasteners.
4. Loosen and remove coolant reservoir mounting fasteners. Detach coolant level sensor harness connector.
5. Check for leaks along seam and at coolant level sensor.
Good luck I hope this helps.
Old May 13, 2007 | 10:02 PM
fong718's Avatar
thanks, will try to give it a shot when I have some time.
Old May 14, 2007 | 07:27 AM
nyboxsterS's Avatar
If you run into any snags I can scan the page with photos out of my service manual and email it to you. It is only one page. Just supply me with your email address. BTW, what part of CA do you live in? I just moved back to NY from SoCal last summer. I lived in Ventura county. I do miss the nice weather but not the wild fires and traffic.
Old May 14, 2007 | 12:15 PM
fong718's Avatar
from norcal.
Old May 14, 2007 | 01:55 PM
Tool Pants's Avatar
Tool Pants is infamous around these parts
Old May 14, 2007 | 02:34 PM
europwr's Avatar
europwr is infamous around these parts
Tool pants...are you learking on here too?
You are everywhere!
Old May 15, 2007 | 09:02 AM
djomlas's Avatar
djomlas is infamous around these parts
check to see if you have the coolant cap ending in 01, the one that ends in 00 will cause problems
COBB Tuning
Jan 1, 2025 09:02 AM
audipwr1
Sep 25, 2021 01:31 PM
turkish1
Nov 11, 2015 09:01 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
Vrseis
Aug 20, 2015 07:41 AM
