dealer says don't lower cayenne
my porsche dealer said i should not put the lowering springs on because it ruins the ride and messes up the wheel alighnment and will make the tires wear out at about 5000. miles what do you think? Oh yes i have a 2006 cayenne s.
Tell dealer he/she is a softy and worries too much about nothing.
Tell him they already wear out tires fast and if he would perform a good alignment to assist in the wearing issue then he would have done you a good service!
Ride comfort is an opinion.
what you have to keep in mind is there are some dealers that are apprehensive towards performing any mods whatsoever. some dealers will balk at the idea and some will work with you.
locate a reputable performance shop that can do the task, and make sure you get an alignment done right after and again 6 months after. you should have no premature wear if the job is done correctly.
Where in Texas are you located?
Lower it then alaign it and you will be ok
Ride quality depends on your suspension choice!
Hit up peter@wheelexperts. He just lowered his cayanne via techart module and he hops between Huston and Dallas I'm sure he can hook you up and u can see the truck in person
I'mAllIn
Sep 11, 2015 06:38 AM
albert@velosdesignwerks
Cayenne
Aug 28, 2015 06:36 PM
Cayenne 958
Aug 19, 2015 02:43 PM
