Hey from UK, One little problem so far :(
new member here, so first of all i'd jus like to say hi to fellow cayenne drivers
had a '54 cayenne, and recently upgraded to a '07 Cayenne S! so far the difference is amazing
i have a little concern though, that you might be able to help with:
Today i was reversing parking on a 40degree incline (nose facing down), so i stuck it into reverse let my foot off the break, and the car started to roll foward as if it wasnt in gear!!?! This wasnt such a problem when parking, but when reversing to leave the space, i had to use the break AND the accelerator, to stop myself rolling into the car infront! I'm sure this isn't normal, as this was not the case in the 54 cayenne.
One service center mentioned that the "Porsche Hill Hold" doesn't work when facing down hill, and another service center said that i shouldn't drive it, and to call Porsche assist to pick it up!!
Sorry for the long message lol, but anyone else experienced a similar problem?
Cheers in advance!
Cheers in advance!
Never had any rolling forward problem in my current CTT or ex-CS. It definitely needs to be looked at by Porsche service. Not sure if you should drive it or tow it there.
BTW you should have kept your "54 Cayenne" as it is the only one that was produced.
oh yea lol, im from UK
, 2 registrations a year; it goes 04, 54, 05, 55 etc.
- so 54 is second 1/2 of 2004
I'll call Porsche assist i guess, maybe try blag a cayenne turbo s as a courtesy car haha, or a cayman (havent had a go in one yet)
Hello buddy,
Let me tell you that porsche hill holder will only work when you are driving forward, when you are in reverse gear, there is no such feature. So, everything is normal, no need to go to dealer.
one thing i have noticed though (although not sure if its related) is the idle rate is 450-500rpm rather then the 800+ normally set?
cheers for the reply - great to know, but in the 2005 cayenne when facing down a hill, and in reverse it held itself inplace (without applying break) - maybe this is just the engine holding it rather then "hill holder"? But either way the 07 Cayenne S just rolls forward (on steep incline! a not so steep incline it holds it self after a little stuttering).
yea the cayenne is a v6, so might be why the idle is different!
As for the rolling issue, its the same hill i usually reverse park on with the v6. The thing is, on slight gradients <20 degrees, it holds it self, so im guessing it's just holding it on the clutch(?). Which would mean the clutch is slipping when on higher gradients??
i'll know more when the service center calls me back, but next time u find urself on a hill, stationary, try it.
evermore
Sep 29, 2016 08:27 AM
MrNurse
Sep 10, 2015 09:44 AM
I-Man
Sep 2, 2015 02:06 PM
