Psm???
Old Oct 22, 2008 | 04:49 PM
katheikia's Avatar
katheikia is infamous around these parts
Psm???
What exactly am I turning off when I push the PSM button. I love the fact that the tranny becomes more agressive, and it doesnt start off in 2nd gear.
Old Oct 22, 2008 | 05:21 PM
Vyper340's Avatar
Vyper340 has a spectacular aura aboutVyper340 has a spectacular aura aboutVyper340 has a spectacular aura about
I'm sure I'll be corrected if wrong but I believe traction control is extremely limited/off, computer switches to more agressive fuel mapping, air suspension goes sport, and the transmission get tweaked. Some cars may also get a revised exhaust note switch too.
Old Oct 22, 2008 | 06:09 PM
katheikia's Avatar
I dont mind if the traction control is off, is it really needed with AWD? Im concerned if there any other saftey features being turned off.
Old Oct 22, 2008 | 08:39 PM
canberk's Avatar
canberk is infamous around these parts
that's wrong. Turning PSM off will not change any suspension setting, however it changes the tranny response. Exhaust and air suspension settings are changed when you enable the sport mode
Old Oct 22, 2008 | 09:22 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
PSM, the button on the dash does what?..??..
I thought it disabled the trac control and that was all......
Are you saying it does more... please explain specifics...
I will have to read the manual now....
Old Oct 22, 2008 | 09:35 PM
mlc.design's Avatar
mlc.design is infamous around these parts
PSM BUTTON DISABLES ALL SAFETY AND TRACTION CONTROLS
ESSENTIALLY TURNS OFF THE COMPUTER.
ABS
Traction Control
All Wheel Drive
Transmission Mapping Harder longer shifts
Rev Limiter
Assisted Steering
Its bad news i would recommend 100% against turning that off
Old Oct 22, 2008 | 11:39 PM
NanaimoCTT's Avatar
NanaimoCTT is infamous around these parts
So this will make it a RWD?? so now i can go on the dyno??
Old Oct 23, 2008 | 12:16 AM
canberk's Avatar
your vehicle is all time awd, so there is no switch for AWD, turning PSM off does NOT switch ABS, All Wheel Drive, Assisted Steering off. It turns traction control off, your vehicle will not gear up when you are at the rev limit, gear mapping changes, ESP is disabled, ASR is disabled. Sometimes it is a good idea to turn PSM off when driving on ice and snow if you think you can handle the vehicle better than the computer (yes you definitely can). Otherwise, no reason to turn PSM off as it is not really interfering with your driving performance nor drifts.
Old Oct 23, 2008 | 03:21 AM
mudman2's Avatar
mudman2 is infamous around these parts
With PSM off you really have no need to worry because as soon as the computer senses you approaching the safe operating envelope limits it turns itself back on. (PSM=Please Save Me)
Old Oct 23, 2008 | 08:50 AM
katheikia's Avatar
Wow now I am even more confused....
Old Oct 23, 2008 | 08:52 AM
canberk's Avatar
RTFM then, before making things up..
randalldahme
Feb 19, 2016 03:56 PM
ophtho
Sep 18, 2015 03:00 PM
Static911
Jun 30, 2004 12:08 PM
james
May 7, 2004 02:28 AM
Captain Bady
Oct 19, 2003 08:46 PM
