How important is the coolant pipe upgrade on an 04 Cayenne TT?
Old Nov 19, 2010 | 02:15 PM
  #46
snzuloz's Avatar
snzuloz is infamous around these parts
Originally Posted by 2muchtime
The intake manifold has to be removed to see the actual coolant pipes??
I'm guessing if you were to use a flexible mirror and a flashlight you would be able to see what is under the manifold as far as plastic lines or the new aluminum setup, I just know that they use a borescope to check the source of leak as that's what was on my Cayenne's repair statement.
Old Nov 19, 2010 | 04:39 PM
  #47
4flynlow's Avatar
4flynlow is infamous around these parts
Has this problem been corrected in subsuquent years? I am looking for a 2008 CTT and one that I just saw stated the two pipes were replaced as part of the CPO process. That being said it appears Porsche has not addressed it through 2008.
Old Nov 19, 2010 | 05:11 PM
  #48
snzuloz's Avatar
My understanding is the 2008+ Cayennes still have potential issues, but they redesigned the coolant lines from the previous version,the newer versions attach cylinder head to cylinder head with a pressed and glued apparatus that can give issues. Maybe someone can chime in if this is correct...
Old Nov 19, 2010 | 06:09 PM
  #49
RobsCountach's Avatar
RobsCountach is infamous around these parts
I've seen the replacement pipes and they're pretty long and its a wide apparatus. Seems like it wouldn't all fit under the manifold... its gotta be outside someplace.
Old Nov 19, 2010 | 06:51 PM
  #50
jr1966's Avatar
jr1966 is just really nicejr1966 is just really nicejr1966 is just really nicejr1966 is just really nicejr1966 is just really nice
Originally Posted by RobsCountach
If you open the hood, its all engine covers and side covers. As I've recently picked mine up, I'd like to know where's the quickest place to check if mine are plastic time bombs or Metal !
You can find that info on either Renntech or Rennlist. Forgot which one but I think it is the latter. It's a way to find out if your coolant pipes are metal or plastic without removing the covers. My indy used that technique to confirm that my pipes are still plastic.
Old Nov 19, 2010 | 10:46 PM
  #51
snzuloz's Avatar
Hopefully this diagram will show you how it works:
Looks as if it all sits under the manifold to me. Updated lines shown.
Jun 10, 2017 07:45 PM
Superaudiofreak
Sep 4, 2015 03:22 PM
orbelo
Aug 30, 2015 12:26 PM
Vrseis
Aug 20, 2015 07:41 AM
