06 Cayenne Turbo S Laser Interceptor install
Old Feb 16, 2010 | 01:22 PM
WaltB's Avatar
WaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond repute
I just finished the Laser Interceptor Quad install with much help from my buddy Ehrin. It’s on my 06 Cayenne Turbo S. We cut the front grill to accommodate the jammers in a stealthy manner and painted them silver to match. The rears are mounted to the license plate screw holes with a custom bracket made by Ehrin and using longer screws. I will follow up and paint these silver also.
The on/Off switch is mounted on the left side panel near right leg when sitting.
I will have the system tested in the next month or so.
Old Feb 16, 2010 | 03:09 PM
hrm's Avatar
hrm
hrm is infamous around these parts
One of the nicer installs I've seen. Great job.
Old Mar 13, 2010 | 09:47 AM
bb996+r1's Avatar
bb996+r1 is infamous around these parts
Nice set up.
Old Mar 15, 2010 | 11:10 AM
Cheeky Monkey's Avatar
Cheeky Monkey is infamous around these parts
Nice job! I'm looking at doing this and have a question, Is there any reason why the sensors could not be seated in between the grills as oppossed to cutting them in to the grill itself?
Old Mar 15, 2010 | 03:16 PM
prsdoc's Avatar
prsdoc is infamous around these parts
Nice install! I've considered doing this myself on our CTT, probably would hide a bit better with our black grilles. Will you paint the overall unit silver, or just add a silver stripe to blend in with the surrounding grille?
Old Mar 15, 2010 | 05:03 PM
WaltB's Avatar
The grill on the 06 TS faces down and I did not feel there was enough room to mount between the slats and still be perfectly level. On the fronts I painted the jammers the same color as the vehicle. So everything is painted silver except the most forward part that the light is emitted through. I am going to paint the rears in a week or so.
Old Mar 16, 2010 | 09:04 PM
Justahonda's Avatar
Justahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud of
Very stealth!
Old Mar 17, 2010 | 03:34 AM
acf's Avatar
acf
acf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to behold
What happened to your S badge?
Old Mar 17, 2010 | 01:28 PM
WaltB's Avatar
Don't know. It was like that when I bought it. Appears to have been installed lower than normal. I did not even notice it until you asked.
Old Mar 22, 2010 | 02:07 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
lovely pics.
Paint those little screws black to blend in.
And if you can spread those rear ones to each side a bit more, like the pics I sent you of mine.
Great look. I am sure it's saved you a few times....
mine has PLENTY>....
socialpro
Cayenne 958
May 18, 2016 09:58 AM
Perkman87
Nov 19, 2015 05:31 PM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
