Problems installing OEM iPod kit
Old Aug 10, 2010 | 10:55 PM
jwccti's Avatar
jwccti is infamous around these parts
Question Problems installing OEM iPod kit
A friend found an unused OEM iPod kit for my 2009 GTS. We did the install earlier today. It *seemed* to go smoothly. The iPod gets power from the adapter cable and the PCM works fine.
However, the car does not find the iPod when I scan the FM dial (as instructed by the included manual from Porsche).
Does this kit need to be activated by a dealer or did I get the wrong kit? Any thoughts would be appreciated.
Thanks, Jim
P.S. This kit interface has two ports: AUX Jack and iPod specific; no USB port exists.
Old Aug 11, 2010 | 09:56 AM
RojoGTS's Avatar
RojoGTS is infamous around these parts
Has to be programmed to car with a code from Porsche just had it done to my 2010 GTS
read here http://www.suncoastparts.com/product...9552S_elec2009
Old Aug 11, 2010 | 10:47 AM
bbywu's Avatar
Thanks, Jim
I'm assuming this is for PCM 2.1, not 3.0 as you said no USB jack. If the kit was for PCM 2.1, then you do not need your car programmed. The interface box has a little switch on the back that sets the frequency of the RF modulator. Did you set that?
There is also an instruction PDF floating around for this kit.
Old Aug 11, 2010 | 10:48 AM
bbywu's Avatar
Your car only needs programming if the kit is for PCM 3.0.
The kit being described is for 2.1...which is a simple RF modulator.
Old Aug 15, 2010 | 08:58 AM
Cayennez1's Avatar
Cayennez1 is infamous around these parts
Where did you buy your kit?? Am looking for one too Thanx
Old Aug 15, 2010 | 01:08 PM
jwccti's Avatar
I didn't see any place to set the frequency of the modulator, but I will check again. Any pointers to the installation manual would be appreciated. I can't find one anywhere!
Old Aug 15, 2010 | 01:11 PM
jwccti's Avatar
http://www.suncoastparts.com/product...52S_elec200708
Old Aug 15, 2010 | 01:35 PM
jwccti's Avatar
Old Aug 15, 2010 | 09:39 PM
Cayennez1's Avatar
That seemed like a lil mission for me.. hope it helps u n thanx for sharing!
COBB Tuning
Jan 1, 2025 09:02 AM
