Tow Hitch Trailer Lights - Brake Problem
Old Sep 22, 2011 | 10:47 PM
FlyYellow's Avatar
FlyYellow is infamous around these partsFlyYellow is infamous around these parts
Hi,
My brake light no longer works on my tow hitch wiring. I purchased a simple 7 to 5 flat converter tester. The five wires are:
Ground
Tail Light
Left Turn
Right Turn
Reverse
Now I would imagine that if the brake pedal is pressed both the left & right turns should light up. They don't - nothing lights up. Am I missing something here??? Any advice?
I'm thinking that perhaps the trailer module controller may be screwed up. I know it used to work. Is there anyway to reset it?
Old Jun 16, 2022 | 10:53 AM
GT3 Chuck's Avatar
Administrator
You do realize that this thread is eleven years old?
Old Jun 16, 2022 | 03:23 PM
Tom_T's Avatar
Tom_T is infamous around these parts
Arrow
However old the thread is, the problem persists with Cayennes, Macans & most other Euro & Brit tow vehicles with the light out software.
For the USA & Canada they usually need to use a regular 7-pin connector with a 7-pin Bypass Adapter like this Reese:
https://www.reeseprod.com/product/20142_trailer-connector-adapter-7-to-7-way
Just in case someone else reads this now that GT3 Chuck has reopened it with his post.
Cheers!
Tom
DogWood
Jun 4, 2022 04:21 PM
XWCGT
May 1, 2014 09:15 AM
FlyYellow
Cayenne 955/957
Oct 15, 2010 01:09 AM
schred
Apr 6, 2009 11:31 PM
Buya02
Jan 25, 2007 05:04 PM
