glass pack muffler
Old Nov 18, 2011 | 04:49 AM
khairo82's Avatar
khairo82 is infamous around these parts
glass pack muffler
can i use a glass pack muffler as a resonatar?? i had a new exhaust system installed and i feel i lost some back pressure,. i was wondering if i can add them as resonatars
thanks
Old Nov 18, 2011 | 11:20 AM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
^ what do you need back pressure for? you want to lose more horsepower? the only reason to add some glass pack mufflers would be to reduce the noise. It would work, and it would probably sound great, but its not going to change performance.
Old Nov 18, 2011 | 11:45 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Glass packs are normally straight through design IIRC. I would throw a flow master on it that's baffled to increase back pressure, but kinda negates your exhaust system now.
Old Nov 18, 2011 | 01:55 PM
khairo82's Avatar
thanks guys,.. not sure if its back pressure or low end torque.. i had cat bypass installed with magnaflow mufflers,. after i installed them i felt like the car performance is different on low gears (2nd gear)..
im not sure what to do but if anybody knows or been through this situation plz help ...
thanks again
Old Nov 18, 2011 | 01:58 PM
split's Avatar
its probably just your imagination. you're expecting more performance relative to the sound. the only thing i could think of is that the magnaflow mufflers were welded on poorly?
Old Nov 18, 2011 | 03:27 PM
03EvoIII's Avatar
Is your Cayenne naturally aspirated? if so, then it's pretty common to lose a little down low end torque feeling when increasing exhaust flow to increase mid-range and high end power. And maybe not lose it, but shift it out in the power curve (higher rpms).
Old Nov 18, 2011 | 11:58 PM
khairo82's Avatar
sorry 03evoIII can you explain more.. what im saying is i have an ml500 06 i did the same thing i deleted the resonator and installed magnaflow mufflers,.. the car lost power.. so i put back the res. and it drove way better,.. but i thought that porsches work better with straight through exhuast.. but i guess its the same thing.
ques. techart mufflers or what ever muffler they use for the cyennes are they stright through mufflers??
Old Nov 19, 2011 | 08:25 AM
03EvoIII's Avatar
yea, I think any of us who has ever put a "high flow" exhaust, or long tube headers, etc, on a torquey engine might have felt a loss of torque lower in the rpms. I know have and it's pretty common. Torque IMO on these cars will make the overall drive-ability better and i think that's your talking about.
I would think that straight through designed mufflers/exhaust on a N/A Cayenne would not be the best for overall drive-ability and performance, maybe just sound.
As for Turbo'd engines...free flow all the way
Old Nov 19, 2011 | 02:18 PM
khairo82's Avatar
i guess your right.. but u know everybody say different thing,.. some say its better some say no.. a bit confussing i think
Old Nov 19, 2011 | 06:37 PM
Bo0stFreak's Avatar
Bo0stFreak is a jewel in the roughBo0stFreak is a jewel in the roughBo0stFreak is a jewel in the rough
You don't need the glass packs unless your trying to change the tone of the exhaust.
speedsterr
Oct 26, 2015 09:18 AM
Oct 2, 2015 02:23 PM
