Coolant change idea?
Thinking to rig a way to use power bleeder to swap coolant fluid. Basically getting new screw cap, will get valve to hook up from cap into power bleeder. Will have small opening to vent any air. Then will get down, open the screw to start draining coolant, while at same time build some pressure to put new fluid into the system. Will not be hard pressure, just enough to put the stuff in replacing old with new. Would keep air from enterng system this way.
Anyone see issues with doing that? Provided done properly, would that be ok/something beneficial for car to do? Thanks
I don't think you will have problems with air pockets. Follow the FSM instructions. Bring it up to operating temp while filling until the thermostat opens. Make sure that you fill up the expansion tank and after the first heat cycle it will bleed itself to a point while cooling. IMHO you don't need to reinvent the wheel on this one.
No, I do not think it will work the way you are thinking. You cannot control the path the fluid follows.
http://www.ecstuning.com/Porsche-200...ing/ES2712734/
Check it brother here you go answer to your question just use this
LiquidElephant
Aug 27, 2015 06:17 PM
