Remote Locking/unlocking
Old Mar 17, 2019 | 09:29 AM
DLF's Avatar
DLF
DLF is infamous around these parts
OK , I've already solved the problem, but I'll retell the tale for the benefit of the forum.
My wife dropped the key fob to the 04 CS. It hit the floor quite hard , splitting the case popping the battery out.
Reassembled it putting the battery back in.
The remote now refused to unlock or lock the car.
The green light on the fob flashed when the button was pressed, but the car did not respond.
I could unlock the drivers door manually with the key, but the alarm sounded until I put the key in the ignition and started it up.
I searched the net for a solution to reprogramming to locking function without much luck, but eventually came across a vague description (on a website which I since
cannot locate again)
Anyway the description said , Unlock the vehicle, then hold down the lock/unlock button for 20-30 seconds. So I did this (while sitting in the drivers seat with the door closed and counting to 30).
Believe it or not, it worked !! Remote is working again !
Hope this helps somebody !
Old Mar 17, 2019 | 10:04 AM
turb0's Avatar
turb0 is infamous around these parts
I have the same issue with the 997.1tt with key 2 which does not remote unlock/lock, but works on the door and the ignition, though key 1 is still fully working.
Old Mar 29, 2019 | 08:53 PM
JSW's Avatar
JSW
JSW is infamous around these parts
Thanks!
Thank you! I tried so many options and none worked. Two different dealers were absolutely worthless and wanted to charge $199 for a diagnostic or $400 for a new fob plus programming. Your idea worked and the fob is perfect.
Old Apr 1, 2019 | 10:52 AM
DLF's Avatar
DLF
Awesome ! Glad the post helped somebody
RoyC
Cayenne Turbo
Dec 22, 2024 10:29 AM
Danno62
Sep 11, 2018 03:31 PM
mindscape9
Mar 9, 2015 08:30 PM
slicky rick
Apr 1, 2014 06:39 PM
