LED license plate light conversion
Old Aug 27, 2012 | 01:14 PM
  #46
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
Thumbs down
Ordered the right part but was sent the wrong item. Ecs is sending out another one but they have to get the wrong one first which makes it about 2 weeks before I can get the in...
Old Sep 23, 2012 | 04:21 PM
  #47
noskis's Avatar
noskis is infamous around these parts
went to order the suncoast lights, but was told (by them) that when they tested it on the new cayennes it gave an error on the dash.
stumbled on these:
http://aznoptics.com/index.php?main_page=product_info&cPath=1_4&product s_id=8
simple plug and play for the license plate bulbs, 19 bucks, no conversion kit needed, and no error message. 5000K model matches the LED DRLs, etc. also comes in amber for the side markers.
Old Nov 22, 2012 | 07:54 AM
  #48
fcsphoto's Avatar
fcsphoto is infamous around these parts
Suncoast LED Replacements
I ordered the Suncoast LED replacement boards (one can hardly call them bulbs anymore!) primarily because they state on their site that they are now error-free, at this date.
Sadly, the ones they sent are defective, producing a dash message and they need to be replaced. I have an RMA and will return the boards, apparently at my cost, for a new set. I'm going to give them another try and hope the new ones will function properly.
Had an easy time with the clear side markers from Suncoast, but they supply normal amber bulbs with their kit.
All replacements are for my 2012 CTT purchased in late August.
Old Dec 26, 2012 | 02:52 PM
  #49
bkmk5's Avatar
bkmk5 is infamous around these parts
I like it!
Old Dec 29, 2012 | 09:22 PM
  #50
dimok's Avatar
dimok is infamous around these parts
Originally Posted by bkmk5
I like it!
do they come with the description of how to swap them?
Old Dec 30, 2012 | 04:47 AM
  #51
bkmk5's Avatar
There may have been, but it 'was so easy, a caveman can do it'
There is only one way the plugs get plugged into one another and the light comes out of the tailgate with a simple push of a clip. The shape of the light is such that you push the resistor to the one side where there will be room once you push the light into the housing and you're done!
Old Feb 14, 2014 | 03:55 PM
  #52
kechang's Avatar
kechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to behold
just thought I would give this thread a bump since it's been a while and things have changed a bit
came across these 2 for the 958
Porsche OEM Parts: http://www.ecstuning.com/ES2217929/
and the ZIZA LED with built in resistor: http://www.ecstuning.com/ES2500790/
reason I am not considering the Racing Dash kit is because it might be way too bright with the 18xLED. My goal is to get it as close to OEM as possible
since the prices are some what affordable for these 2, I will buy them and try it and post my experience with them
a lot of VW are getting the OEM porsche one instead of the VW that turbostang originally posted since it's cheaper and works the same
Old Feb 14, 2014 | 05:39 PM
  #53
AZN_C300's Avatar
AZN_C300 is infamous around these parts
Using these in mine and have had no issues and canbus units with built in resistors so error free . Rear plates and also front sidemarkers (swapped for clear) and blinks normal rate when signaling. $19 only per set and free shipping.
http://aznoptics.com/index.php?main_...&products_id=8
Old Feb 17, 2014 | 04:52 AM
  #54
Z3RO's Avatar
Z3RO is infamous around these parts
Can you post some pics of yours? Thanks.
Old Feb 17, 2014 | 10:39 PM
  #55
AZN_C300's Avatar
Here's a couple quick shots. Pure brilliant white.
ID:	335211   Click image for larger version
Old Feb 18, 2014 | 02:44 AM
  #56
Matt911's Avatar
Matt911 is infamous around these parts
How long have you had them? They look great, just the right amount of brightness.
Old Feb 18, 2014 | 12:17 PM
  #57
AZN_C300's Avatar
I've had them in for about 6 months now. Simple DIY. Plate light housing is attached via tabs so just use your fingers or a flat head against the tab and it pops right out. Then just twist the base off the housing to have access to the bulb. Pull it out, plug in the LED, check for polarity, and good to go.
Old Feb 18, 2014 | 07:07 PM
  #58
TGED's Avatar
TGED is infamous around these parts
AZN_C300, do you have problem with overheating with these LEDs?
Old Feb 18, 2014 | 08:22 PM
  #59
HOiYA's Avatar
HOiYA is infamous around these parts
I ordered a set of AZN Optics to try out. They weren't terribly expensive so I thought it was worth a try. If they do overheat, going to try the OEM ones from ECS.
Old Feb 18, 2014 | 08:39 PM
  #60
TGED's Avatar
Please report back, thanks.
