LED license plate light conversion
Old Feb 28, 2014 | 12:37 PM
  #76
kechang's Avatar
kechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to behold
looks like it matched the horseshoe LED very well!
Old Apr 30, 2014 | 08:19 PM
  #77
Matt911's Avatar
Matt911 is infamous around these parts
Originally Posted by AZN_C300
Plate light housing is attached via tabs so just use your fingers or a flat head against the tab and it pops right out. Then just twist the base off the housing to have access to the bulb. Pull it out, plug in the LED, check for polarity, and good to go.
I've managed to pop the left housing easily. But the right one is just too stubborn, is there a trick to pop this thing?
Old Apr 30, 2014 | 08:27 PM
  #78
kechang's Avatar
I wrapped the head of the long nose plier with microfiber towel and just grab the tab and pull down
my right side was stubborn too
Old Apr 30, 2014 | 08:30 PM
  #79
AZN_C300's Avatar
AZN_C300 is infamous around these parts
Probably just the accumulation of dust and grime. Mine came off fairly easily, but I blast my car with a pressure washer regularly so probably keeps it clean
Old May 3, 2014 | 08:32 PM
  #80
TGED's Avatar
TGED is infamous around these parts
AZN_C300, are your AZNOPTICS LEDs still working without overheating? Do you do frequent night driving?
Old May 3, 2014 | 08:55 PM
  #81
HOiYA's Avatar
HOiYA is infamous around these parts
I've had mine for a couple months now and have had no issues so far.... Knock on wood!
Old May 3, 2014 | 11:57 PM
  #82
AZN_C300's Avatar
No issues.
Old May 4, 2014 | 05:37 AM
  #83
TGED's Avatar
My previous LED plate lights were working fine for months but they burnt out after one night of 6-7 hours driving.
Old May 5, 2014 | 04:00 PM
  #84
kechang's Avatar
2000 miles later, my OEM one works flawlessly
Old May 5, 2014 | 06:04 PM
  #85
TGED's Avatar
kechang, I assume you got the following, right?
http://www.ecstuning.com/ES2217929/
Do they have built in resistors? Which Porsche model are these designed for? I don't think Porsche has any model that come with standard LED plate lights. I am not sure about the e-hybrid.
Old May 5, 2014 | 06:13 PM
  #86
kechang's Avatar
pls visit here for my retrofit, it will have all the details
https://www.6speedonline.com/forums/...-free-way.html
Old May 5, 2014 | 06:48 PM
  #87
TGED's Avatar
So the Porsche OEM requires an external resistor module. But other forum members have successfully used LEDs with built-in resistors without issues with over heating. If both methods work, the later is much more simple which involves just replacing the bulbs.
Old May 5, 2014 | 07:03 PM
  #88
kechang's Avatar
Depends on what u are looking for. For me, no aftermarket led will beat the oem look and I have about 10 pairs of different led at home just because I'm that picky
If u are looking just easy simple replacement. Led with built in resistor will do you just fine. But compared to retrofitting turbo bumper/led drl into none turbo cayenne is 100x harder than this retrofit and the light looks great at night. It's perfect imo.
Old May 7, 2014 | 05:03 PM
  #89
Matt911's Avatar
To be honest the azn leds doesn't look white like the rest of porsche leds. It has a blueish hue, and i dislike that. So i've put back the oem ones.
The_Ruski_Driver
Oct 25, 2015 08:40 PM
RallyBird
Oct 7, 2015 01:20 PM
Jaytaylor10485
Aug 28, 2015 06:25 AM
