LED license plate light conversion
Old Feb 19, 2014 | 03:33 PM
  #61
kechang's Avatar
kechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to behold
yea please report once you get it... picking up my car Friday and would love to finish up all the small things
Old Feb 22, 2014 | 05:12 PM
  #62
HOiYA's Avatar
HOiYA is infamous around these parts
So I was only able to install one of the lights. The way my laser diffusers are installed on the back is blocking the right light housing from being unclipped. I am seeing my installer later this week and will have them fix that. But attached is the a pic of the difference.
-S
Old Feb 24, 2014 | 05:05 PM
  #63
kechang's Avatar
how is the light output compared to some of the OEM ones you see on the road?
my main concerns are the correct kelvin temp and the output
Old Feb 27, 2014 | 01:09 PM
  #64
HOiYA's Avatar
So I installed them late last night, but didn't get a chance to take a pic of it. I will try and do that tonight. The output is definitely brighter than the stock amber bulb.
The only complaint I have with the bulb is they seem a little fragile. While I was getting some work done on the laser diffuser's, the bulb was unseated. Popped them out to re-seat it and the top part broke off. Not sure if the ECU ones would be any different. Luckily I ordered 2 sets as I was thinking of replacing the side blinkers with LED's as well.
Old Feb 27, 2014 | 01:44 PM
  #65
AZN_C300's Avatar
AZN_C300 is infamous around these parts
There's a 1 year warranty on their units so I'd contact them to get that replaced.
Old Feb 27, 2014 | 02:57 PM
  #66
HOiYA's Avatar
Thanks I'll reach out. Do you know if these will work as replacements for the side turn signals?
Old Feb 27, 2014 | 03:41 PM
  #67
tonyep's Avatar
tonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of light
You'll need a load resistor to use the as turn signals or they'll hyper flash but anyway they uses a different bulb type.
Old Feb 27, 2014 | 05:27 PM
  #68
AZN_C300's Avatar
You mean the sidemarkers that flash on signal? Yes, they work and no they do not hyper flash. Don't need load resistors.
Old Feb 27, 2014 | 05:50 PM
  #69
kechang's Avatar
woah just realized they are local in Chino hills and you are from there too
do they allow us to just pick it up ?
Old Feb 27, 2014 | 06:01 PM
  #70
AZN_C300's Avatar
No, but you can pick up from some local stores that distribute (Xsthetic Motorsports for example)
Old Feb 27, 2014 | 06:10 PM
  #71
kechang's Avatar
okay thanks, I'll probably order a set if the OEM ones didn't work out, I'll have to get my guy to do the custom resistor for it
the iJDYtoy/ECS one DO look nice but I personally think it's a bit too bright (especially too much projection to the ground)
Old Feb 27, 2014 | 06:17 PM
  #72
AZN_C300's Avatar
It's great if you drop something back there at night though
I think also with yours being white, it'll tend to reflect the light more though because that looks really bright in the pic.
Old Feb 27, 2014 | 06:29 PM
  #73
kechang's Avatar
yea, it's really hard to capture the light correctly at night, it sure look a lot better and cleaner in person but compared to all the OEM LED out there, this is like 10x the brightness
you sure are right about the white being more reflective, here's the OEM one on my white GS, super bright too
Old Feb 27, 2014 | 06:30 PM
  #74
koolrider101's Avatar
koolrider101 is infamous around these parts
LED looks so bright!
Old Feb 27, 2014 | 09:38 PM
  #75
HOiYA's Avatar
Here's a shot of the AZN LED's
