Replacement Brake pads
I'm at about 13k miles and I'm thinking about changing brake pads front and rear. I'm not going with OEM because of the dust issue. I am looking at EBC Red Stuff. Does anybody have any experience with EBC brakes? Any other recommendations?
I don't know if it would be the same for Porsche but when I had the same problem with my Mercedes I switched to Akebono pads and they stopped the dust 98%. I was amazed at the difference.
Thanks for looking into it for me. I just ordered the EBC Red Stuff brakes. I'm going to order the brake sensors next. I'm wondering if i'd be able to re-use them if my mechanic removes them carefully. Hmmmm...
i dont know if all of them are or not for the cs and pannys, but ive bought oem panamera s and cayenne brake pads from porsche dealers part dept and when i opened the box the pads were made by akebono for porsche. i kno for 911's ive seen oem pads made by ferado, jurid, etc. first time ive seen akebono as a oem porsche supplier. and no need to buy new sensors, u can reuse the old ones, use a pick or small flat head and they just pop out
Just when I thought my brakes were on their way I get this e-mail....
"Unfortunately there was a cross over year from 2010-2011. We need to make sure what pads you have on your vehicle. Please find attached pad outlines, if you can verify which pads you have on your vehicle.
Front – 2010 Porsche Cayenne Turbo 4.8L - DP31905C
Rear – 2010 Porsche Cayenne Turbo 4.8L - DP31474C
Front – 2011 Porsche Cayenne Turbo 4.8L – DP41835R
Rear – 2011 Porsche Cayenne Turbo 4.8L – DP42098R
If you have the lower pads, please give us a call. That vehicle is only available in YellowStuff pads and there is an additional $84.87 needed to complete this order. If not, then we are ok to proceed with your order. Thank you for your help with this situation."
How can I confirm which brakes I need?
assuming you have a 958 MY 11, 12 or 13 cayenne turbo then u need the bottom two pads. 2010 was the face lifted last gen cayenne which uses different calipers then the 958s, theyre basically saying you can only get them in yellows and you need to pay the price increase difference.
What you give up in dust creation will be balanced by higher disc wear. energy from braking has to be dissipated some way!
Now lets hear all of the anecdotes about how your braking is better and produces less dust, yadda, yadda, yadda!
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
