the NEW Cayenne requires 93 Octane gas
Old Dec 19, 2012 | 09:29 PM
dawninglawrence's Avatar
dawninglawrence is infamous around these parts
Exclamation the NEW Cayenne requires 93 Octane gas
Hi everyone, I read that Cayenne required 93 Octane gas??? I don't have any Octane 93 gas in my area, San Francisco. Does anyone drives a cayenne without 93 octane gas? any difference? any damage this will cause? Thanks
Old Dec 19, 2012 | 10:36 PM
grohgreg's Avatar
grohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of light
I think that means 93 minimum. In other words, it needs premium grade fuel..
//Greg//
Old Dec 20, 2012 | 08:19 AM
LaicepsYdobon's Avatar
LaicepsYdobon is infamous around these parts
93 is the preferred octane for the Cayenne but it runs fine on 91. There were a couple of times when I had to fill her up with 91 because of the unavailability of 93. I personally have not noticed any difference in power and/or consumption. With both octanes I can go around 400 miles on one tank if I'm behaving. The engine is able to cope with lower octane/quality gas by adjusting itself to prevent "knocking". If you search around on either this board or on Rennlist's Cayenne forum people have filled up with 87 in a pinch without any adverse effects.
Old Dec 20, 2012 | 09:18 AM
Da Hapa's Avatar
Da Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of light
Another benefit of living in CARB controlled California. You can't get 93 octane gas here. You can blend some race gas with 91 but that will cost a fortune.
Your predicament is faced by thousands of other Porsche owners here in the great state of California. Your Cayenne should run fine on 91 although you are likely losing a few bhp and perhaps a bit of MPG. No long term problems, just use high quality gas.
BTW - my Carrera S does respond well to 93 octane gas when I'm in other states. My guess is that the Cayenne would do the the same.
Old Dec 20, 2012 | 10:52 AM
N/A's Avatar
N/A is infamous around these parts
Wow you guys run 91 and 93 octane?!? Premium here on regular is 95 and our high octane which I use is almost 100.
Old Dec 20, 2012 | 12:10 PM
Da Hapa's Avatar
Be careful in your comparisons. I hope someone corrects me if I'm wrong, but octane ratings across countries aren't uniform. It's my understanding that Europe uses a different methodology than the US and my guess is so does Japan.
Old Dec 20, 2012 | 02:30 PM
steph280's Avatar
steph280 has a spectacular aura aboutsteph280 has a spectacular aura about
My 997 says 93 octane only and I ran it on 91 octane for years without issues. Like the above said, California does not have anything higher than 91, unless if you go buy 100 octane racing gasoline.
However my 2012 Cayenne says 91 octane, not sure why they changed back to 93 for 2013?
Old Dec 20, 2012 | 05:13 PM
grohgreg's Avatar
Had my CD in the shop yesterday - warranty work. They gave me an Audi Q5 loaner. It was the 2.0T, and the label on the filler door says use 95 octane. Didn't know where to find 95 in Nashville - if it even exists - so I topped it up with 93. Told the dealer when I turned it back in, he wasn't too concerned.
//greg//
Old Dec 20, 2012 | 05:33 PM
nhirsch's Avatar
nhirsch is infamous around these partsnhirsch is infamous around these parts
I seem to remember that when I picked up my European Delivery Cayenne Turbo, I signed something to the effect of using nothing less than 95 European (RON) Octane and that they would test the car and if I had violated that, the cost would be $2000. It might have also had to do with leaded gas and the catalytic converter and US regulations. I didn't worry about it because I always use the highest test possible although when I saw 100 RON octane in Europe, I opted for the 98 due to cost. The gas cap shows two minimum ratings, Research Octane Number (RON) of 95 and the Anti-Knock Index (AKI) or (R+M)/2 of 91 which is the US rating.
Old Dec 20, 2012 | 06:02 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Our 01 996 has a similar requirement, but even the occasional half asleep 87 fill is fine (though there is a noticeable loss of power).
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
Sep 1, 2015 03:16 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
