GTS/Turbo Bumper Swap + Working DRLs
Old Jul 23, 2013 | 09:40 AM
Ylincooper's Avatar
Ylincooper is infamous around these parts
I think I am going to cry...
Old Jul 23, 2013 | 05:24 PM
_Cayenne_S_'s Avatar
_Cayenne_S_ is infamous around these parts
Nice job congrats i want to do this since a long time but the dealer told me that i will lose the DRLS and they can't make the light bar ON like S model. Where did you ordered the harness if I may ask you?
Old Jul 23, 2013 | 11:44 PM
snp_cayenne's Avatar
snp_cayenne is a jewel in the roughsnp_cayenne is a jewel in the roughsnp_cayenne is a jewel in the roughsnp_cayenne is a jewel in the rough
The dealer is right. The DRLS are in the headlights for the Turbo/GTS and the bumper only has the horizontal parking lights and yellow turn signals, whereas the S has an extra set of lights in the bumper (yellow turn signal, thin horizontal parking lights, and horizontal DRLs). The bumper conversion kits out there use the Turbo wiring harness, which is why you lose the DRLs (don't have the right pins).
I used the orignal harness from the S, but I built my own harness adapter for the Turbo/GTS bumper lights to make them work properly and also allow the horizontal LEDs to work as both DRLs and parking lights. They do require a couple simple electronic components.
I've been traveling and haven't had a moment to do a full write up on how to build the adapter yet.
Old Jul 27, 2013 | 05:11 PM
Originally Posted by snp_cayenne
The dealer is right. The DRLS are in the headlights for the Turbo/GTS and the bumper only has the horizontal parking lights and yellow turn signals, whereas the S has an extra set of lights in the bumper (yellow turn signal, thin horizontal parking lights, and horizontal DRLs). The bumper conversion kits out there use the Turbo wiring harness, which is why you lose the DRLs (don't have the right pins).<br />
<br />
I used the orignal harness from the S, but I built my own harness adapter for the Turbo/GTS bumper lights to make them work properly and also allow the horizontal LEDs to work as both DRLs and parking lights. They do require a couple simple electronic components. <br />
<br />
<br />
<br />
<br />
if I Decide to buy the Gts front headlight complete set will the DRLs work on my CS like the Gts or I still need some electric work to make them work. <br />
Any advise.
Old Jul 27, 2013 | 11:38 PM
<br />
<br />
<br />
Any advise.
If you get the GTS headlights (which include the DRLs in them), you will have to redo the wiring on the S. The DRL signal is in the bumper led bar harness in the S and in the GTS/Turbo the DRL signal is in the headlight harness.
Old Jul 28, 2013 | 07:57 AM
ok how difficult is to do the wiring to convert the DRLs from the S to Gts assume that I have already bought the Gts headlights I am sure there is away!
Old Jul 28, 2013 | 08:00 AM
Ylincooper's Avatar
Any write up on the schematic?
Old Jul 29, 2013 | 06:44 PM
hagel's Avatar
hagel is infamous around these parts
I'd appreciate a write up / how to on the wiring schematic, as I've been on the fence on doing the swap on my CD. If I could do it and keep the DRL, I'm all in!
Old Aug 1, 2013 | 11:09 AM
Ylincooper's Avatar
Originally Posted by anakongkong
Here is connection.
From Car -
Pin # 9 = Yellow /blue : Right side DRL.
Pun #10 = Yellow/green : Left side DRL.
connect wire to Turbo DRL.
not sure LED pins but from Left, it was Ground pin, DRL, Light, Turn signal (all 4 pins on LED plug on bumper) or Ground-light-ground-turn
Good luck guys!
anakongkong, not going to lie, this is kind of confusing. Thank you very much but do you think you could elaborate a little bit more on each step of the process?
Old Aug 29, 2013 | 09:43 PM
jayhay82's Avatar
jayhay82 is infamous around these parts
I ordered a kit from suncoast. Terrible experience. Received kit with missing parts and duplicates parts. I asked if the reinforcement bar was necessary and they said that it wasn't. Well they were wrong and I have to wait an additional week to get my pig back from the shop.
I am interested in the working DRLs with the turbo conversion. Any updates?
Old Aug 29, 2013 | 10:02 PM
I had the same experience with getting extra parts and missing a couple others, but Suncoast was really good about taking care of it. As I mentioned in an earlier post, the reinforcement bar is different (as is also the foam block) and that's the only thing that is missing in your their full kit.
When I get some time, I'll post the schematics on how to build the harness to allow the LED bars to double as both the parking lights and DRLs.
Old Sep 2, 2013 | 04:58 AM
Swiss made's Avatar
Swiss made is infamous around these parts
Techart has a DRL which would be an upgrade for the OEM turbo bumper or will be part of their Magnum kit. I assume you can also use this kit on a normal Cayenne with Turbo bumper.
Go to page 6 on http://www.techart.de/fileadmin/cont...0991626186.pdf
Old Sep 2, 2013 | 10:16 AM
I've looked into those before. They will work on a normal Cayenne with a Turbo bumper. The Techart DRL kit comes with its own controller. You just need to splice into your current harness for power and signal.
Old Sep 2, 2013 | 10:55 AM
HOiYA's Avatar
HOiYA is infamous around these parts
Yeah I came across those on the sharkwerks site and then saw the price tag.... a whopping $1600 and that doesn't include install. Definitely cool, but not sure if that is where I would spend the money.
Old Sep 2, 2013 | 11:03 AM
That's right. It's pretty expensive and it does require you to trim and modify the LED bar holding bracket for the Techart DRLs to mount properly.
