Install a PCM 3.1 on Cayenne Diesel With CDR 31
Old Dec 23, 2013 | 07:47 AM
  #46
VL_599's Avatar
VL_599 is infamous around these parts
Originally Posted by G_A
no.
You should change connector housing.
use 970.044.900.99
or universal coding blue housing.
According manual you have to change antenna amplifier, 958.647.312.01
But this will not improve FM reception imo.
Ok, on past list add connector housing 970.044.900.99
and it can be connected to the existing fm antenna?
radio can operate without this antenna amp or not?
oh more complicated)
Do you know the price for this antenna amp?
Old Dec 23, 2013 | 08:15 AM
  #47
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
yes. They will remove original antenna connector and will use new one.
Porsche suggest replace right antenna amp, but imo this will not change reception.
price for amp about hundred euro.
Old Dec 23, 2013 | 10:11 AM
  #48
VL_599's Avatar
Ok, I will order connector only, I will try without antena amp,
I do not understand what the purpose of installing the amplifier?
if this will not change reception. I'm confused about this issue,
what is the name of this installation manual/procedure?
I want to tell them exactly(porsche service)
thanks
Old Dec 23, 2013 | 10:22 AM
  #49
G_A's Avatar
G_A
Tuqipment
9110
I am sure they know. Only one manual how to retrofit PCM.
Old Dec 24, 2013 | 01:27 AM
  #50
VL_599's Avatar
no.
use 970.044.900.99
One more thing,
Vehicles with factory equiped pcm 3.1 system has front dashboard center speaker.
I think it is 80mm speaker (1 pcs).
On my car with cdr31 system I do not have this speaker.
Is it possible to add this speaker now when I adding an amplifier?
is it easy to connect to new apm? I can order this speaker.
Old Dec 24, 2013 | 02:24 AM
  #51
G_A's Avatar
G_A
In original retrofit they do not install this speaker.
But you can. need speaker, oe, not expensive, and route two wires to the amp and find two suitable round pins (contacts).
Old Dec 26, 2013 | 01:41 AM
  #52
VL_599's Avatar
Originally Posted by gnat
If you guys are going to all this trouble I would suggest the new 2014 PCM as it added additional features (HDD, album art, etc...).
That would mean a new unit though I expect..
PCM 3.1 which I bought is removed from 2013 Cayenne.
made on 04.october.2012.
Part no is: 958.624.970.01
I will recieve it in 10 days.
How do you think, Will I have new functions? hdd and album art?
Old Dec 26, 2013 | 03:02 AM
  #53
G_A's Avatar
G_A
95862497001 - looks like wromg number
oh, it is not part number, i see.
Old Dec 26, 2013 | 03:19 AM
  #54
G_A's Avatar
G_A
and should not allow jukebox features.
Old Dec 26, 2013 | 04:45 AM
  #55
VL_599's Avatar
This Pcm is made in october 2012.
They said "Jukebox is a standard feature on all Cayennes production starting Nov, 2012. We will see..
I noticed, some pcm have DISC button and some have a MEDIA button?
Mine is with MEDIA button.
Old Dec 26, 2013 | 04:53 AM
  #56
VL_599's Avatar
Part number is not on the sticker?
Old Dec 26, 2013 | 07:39 AM
  #57
G_A's Avatar
G_A
Yes, this is part number.
Not exact, but it is.
suit for cars MY "C", so I do not know exactly will jukebox works or not.
Old Jan 2, 2014 | 04:34 AM
  #58
VL_599's Avatar
Happy New year!!
Pcm will arrive this week, fakra antenna next week.
One question, another topic.
Is it possible to add unlock/lock button on doors on Cayenne 958.
My car is made on december 2011, and Porsche added this feature on january 2012 cars. Cost?
Old Jan 2, 2014 | 08:18 AM
  #59
G_A's Avatar
G_A
Yes.
I did it once.
Need some time for proper coding door control units,
install button, let say 100 Euro each, carefully cut oe handle inserts, use suitable connector for handle switch, route wires to door unit, and insert pin in the control module connector.
2 hours for both front doors.
OE button and led in door buttons works well.
Old Jan 8, 2014 | 12:54 PM
  #60
VL_599's Avatar
Yes.
I did it once.
That is great! I want to do the same.
But first to finish the conversion of PCM system
PCM has finally arrived. looks great!
I'm just waiting to get the GPS antenna. I ordered on ebay 10 days ago.
wiring and apm I will order in a few days.
One question about purple connector on pcm, what is it?
