Install a PCM 3.1 on Cayenne Diesel With CDR 31
Old Feb 22, 2014 | 02:27 PM
  #61
TXTurbo's Avatar
TXTurbo is just really niceTXTurbo is just really niceTXTurbo is just really niceTXTurbo is just really nice
Originally Posted by VL_599
That is great! I want to do the same.
But first to finish the conversion of PCM system
PCM has finally arrived. looks great!
I'm just waiting to get the GPS antenna. I ordered on ebay 10 days ago.
wiring and apm I will order in a few days.
One question about purple connector on pcm, what is it?
Did you ever get your retrofit of the PCM working?
Old Feb 24, 2014 | 12:28 AM
  #62
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
Yes) I know)
Old Feb 24, 2014 | 06:51 AM
  #63
TXTurbo's Avatar
Originally Posted by G_A
Yes) I know)
That's good news!
So...
If I want to update a 2011 PCM to a 3.1 system do I just need a new head unit?
My system has Navigation, Burmester, Bluetooth, XM satellite, 6 disk changer and voice control.
Old Feb 24, 2014 | 06:55 AM
  #64
G_A's Avatar
G_A
2011 MY cayenne already with PCM 3.1)
Old Feb 24, 2014 | 06:57 AM
  #65
TXTurbo's Avatar
Yes... I mean the newer system. With album art and other features.
Basically upgrading to the 2012-2014 system
Old Feb 24, 2014 | 07:18 AM
  #66
G_A's Avatar
G_A
I do not know exacly.
Nobody try here.
ask VL_599, he have old headunit with latest firmware.
Old Feb 24, 2014 | 07:10 PM
  #67
TGED's Avatar
TGED is infamous around these parts
Album art and Jukebox start part way through the 2013 model year on vehicles built from Nov 2012. Online service also became available. Because there is a built-in hard drive for the Jukebox, perhaps there is a hardware change also.
Old Feb 27, 2014 | 01:24 PM
  #68
VL_599's Avatar
VL_599 is infamous around these parts
Used PCM unit which I bought is made on october 2012. removed from 2013 car. It's a little early for album art? I can not check album art becouse I don't have usb on my car. Software version is 3.42.
By the way, I am impressed with the system pcm 3.1 in relation to standard cdr31.
Old Feb 27, 2014 | 02:04 PM
  #69
VL_599's Avatar
Sorry for late reply,
Yes, everything works perfectly.
(My pcm is made in october 2012, from 2013 car..)
Software version is 3.42. I want album art also...
Old Feb 27, 2014 | 08:22 PM
  #70
TGED's Avatar
I believe album art is also displayed on CDs that have metadata attached to each song file.
Old Aug 21, 2014 | 02:07 PM
  #71
mickaelo's Avatar
mickaelo is infamous around these parts
Hi, id'like to do exactly the same on my 2011 cayenne. I had read all posts, will you recommend to do the same , what is the main difficult to do.
did you make documentation, picture anything else???
thanks
Old Aug 21, 2014 | 02:11 PM
  #72
mickaelo's Avatar
HI GA, you seems the expert for conversion, I d like to make exactly the same.
I found a unit on market which seems to be for panamera, does it fit with cayenne also
My is 2011 model.
Regarding the amp kit to be done for non boose, does it mandatory?
Does the speakers are working without?
thanks
Old Aug 24, 2014 | 12:48 AM
  #73
G_A's Avatar
G_A
My is 2011 model.
thanks
Panamera pcm has different shape first of all.
You will hear sound on low volume if connect pcm directly without amp.
Old Aug 24, 2014 | 04:18 AM
  #74
mickaelo's Avatar
Hi GA, thanks for your prompt answer.
I ask the question because you can find unit on the market which are round angle and also square angle very similar to Cayenne model but sell as "panamera compatible"
Is there a model to specify when we look for this unit dedicated to cayenne to be sure?
I'm currently have only CDR and as conversion taking time , would like to get Bluetooth fonctionnality
does the codes for CDR and PCM are the sema for this fonctionnality or would I have to buy a second time when i'll done the conversion to PCM?
What is a reasonable cost to get the code VS Porsche dealer directly?
Thanks again for your help
Old Aug 24, 2014 | 06:18 AM
  #75
G_A's Avatar
G_A
You need CAYENNE pcm, not panamera compatible.
Bt code buy new one.
Try ask dealer for code, but imo no chance get code officially until you pay $$$$$$ dealer for official retrofit.
