VRtuned Tuning Box for 958 3.6L Cayenne S/GTS
Old Jan 15, 2016 | 01:46 PM
vividracing's Avatar
Now available!! The VRtuned tuning box solution that allows you to get huge power without sacrificing reliability or having to worry about warranty issues. This is a plug and play solution that connects to a few sensors in your engine bay. If you need to take your car in for warranty, just unplug and you are good to go, the dealer will not be able to detect it(unless its sitting in the engine bay )
We have run these kits on our Project 991tt, Project CLA45, Project Mclaren and many more!
PM with any questions and for forum member pricing specials
Old Jan 21, 2016 | 12:37 AM
jtorrebl's Avatar
jtorrebl is infamous around these parts
what HP torque gains. Any dyno info?
Old Jan 21, 2016 | 09:27 AM
It has not been dyno'd at our shop, but our partner in the UK who manufactures the box tested it at
+72 HP and +110 ft/lbs torque to the crank.
Old Feb 15, 2016 | 05:59 PM
vreynaud's Avatar
vreynaud is infamous around these parts
for a Cayenne S (non turbo)???
Old Feb 16, 2016 | 08:51 AM
The New S do have turbos
Old Feb 16, 2016 | 09:08 AM
P997S's Avatar
P997S is infamous around these partsP997S is infamous around these parts
is this for 2016 GTS also ?
Old Feb 16, 2016 | 09:37 AM
Yes, this will work on a GTS
Old Feb 17, 2016 | 11:50 AM
[SS]Shooter's Avatar
[SS]Shooter is infamous around these parts[SS]Shooter is infamous around these parts
I'm familiar with using piggyback product (such as a Power Commander) on motorcycles. Do your products work in a similar fashion?
A lot of people on the forums seem to recommend custom software (from GIAC and others) over piggyback tuning boxes, such as the one you are selling here. Can you explain the pros/cons of a piggyback box vs. custom software.
Also, can you provide some details on how your box increases power? Does it raise the boost level? That would seem to be the low hanging fruit to get power from the 3.6L TT motors. If so, how high does it go?
Thanks.
Old Feb 18, 2016 | 04:53 AM
P997S's Avatar
+1
Thanks.
me too thanks!
Old Feb 18, 2016 | 09:35 AM
Sure thing, all great questions. This tuning box will work identical to similar to how a power commander works. This specific one connects to the boost pressure sensor, camshaft position sensor, and manifold air pressure sensor. Typically, an actual ECU flash will yield more power. The main benefit of a piggyback system is that it is removable and undetectable by dealerships; since it does not actually flash the ECU, once its off there is no way to tell it was on there. The main source of power will be from increasing the boost.
One of our customers, Jesse, posted up his install and review of the box on his 3.6L turbo Macan
https://www.6speedonline.com/forums/...pic-heavy.html
including his times in the last comment
jpflip
Jan 21, 2016 07:29 PM
Red911TT
Dec 10, 2015 10:54 PM
Erik@RSC
Dec 8, 2015 03:46 PM
Harris@TPCRacing
Dec 4, 2015 09:14 AM
ECS Tuning - BMW
Dec 3, 2015 11:52 AM
