15 Cayenne Diesel Oil Level Sensor
Old May 7, 2016 | 08:06 PM
ash_cpe's Avatar
ash_cpe is infamous around these parts
Question 15 Cayenne Diesel Oil Level Sensor
Hello folks,
My CD has 10K miles on it. I went to the dealer to have an oil change done. When I drove back home, I got "Oil Level is above max, visit workshop soon" warning. I went back to the dealer and they extracted some oil, I got same message again "Oil Level is above max, visit workshop soon" when I got home. I visited the dealer and they measured oil using their special dipstick and said oil level is fine, it might be the sensor. I also took it to another dealer, they said oil level is fine (Half way from Min to Max) using their dipstick. Now, why did sensor fail only after 2nd oil change? Have you guys seen this warning before? Any advice?
Thank you.
Old May 8, 2016 | 11:50 AM
Rob VN's Avatar
Rob VN is infamous around these parts
Have them replace the oil level sensor. It is a high class VW-Audi part....
Old May 8, 2016 | 03:27 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Even new parts fail, that's why you have a warranty. Schedule a visit and they'll replace it.
No issues with my 13 and I haven't read any complaints so I don't think it's a common issue.
Old May 10, 2016 | 09:48 AM
ash_cpe's Avatar
Thanks. I am waiting for the dealer to get back to me regarding sensor availability.
Does anyone know of an accurate dipstick that can be used for 15 Cayenne Diesels?
Old May 10, 2016 | 10:45 AM
gnat's Avatar
There is a dealer tool you can get ($$$), but it can not be left in the motor.
Some people have mentioned using dipsticks from the previous generation Q7/T-Reg (e.g. 957 siblings as the current variants don't have dipsticks either) and I haven't seen any issues reported, but I'm leery of that practice since we don't have details on what the proper length should be.
Old May 10, 2016 | 06:31 PM
RickDC's Avatar
RickDC is infamous around these parts
I've just ordered this from eBay... Correct part number for the cayenne/toureg. At $16 it's a risk I'm quite happy to take!
http://www.ebay.ca/itm/281879873197?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old May 11, 2016 | 08:01 PM
Boostaddiction's Avatar
Boostaddiction is infamous around these parts
I'm using a modified Audi dipstick. Just need to trim a bit off the handle.
Old Jul 19, 2016 | 12:11 PM
93RSAmerica's Avatar
93RSAmerica is infamous around these parts
Anyone else having CD oil level and oil temp issues?
2013 CD ~56k miles - Have had oil level and oil temp issues twice.
First time the level went to minimum and the temp spiked to 238F at the end of a multi day trip doing 60mph. No prior issues with level or temp, having two air-cooled 911s I always monitor the oil. Called Porsche roadside assist, they suggested adding oil which I did - then got an overfill indication. Dealer sucked excess and both level & temp went back to normal.
Couple of months later same issue again ~700 miles after an oil change. Dealer replaced the oil sensor that monitors both level & temp. They also reduced the oil level so it is one bar below max to allow for expansion.
Had dealer measure level with shop dip stick to baseline oil level. While I believe this is an indication issue, want to verify our CD is not loosing oil.
Old Jul 19, 2016 | 06:12 PM
b-man's Avatar
b-man is infamous around these parts
I did the same. Now I know my electronic gauge is not accurate.
b-man
Old Jul 19, 2016 | 08:11 PM
CarGuyNyc's Avatar
CarGuyNyc is infamous around these parts
Over 30,000 miles on my 2015 CD, I have not had this issue.
CarGuyNyc
Apr 14, 2016 05:33 AM
rockygregs
Apr 14, 2016 04:00 AM
PelicanParts.com
Apr 12, 2016 10:37 AM
PelicanParts.com
Apr 12, 2016 10:36 AM
PelicanParts.com
BMW Vendor Classifieds
Apr 12, 2016 10:34 AM
