Sunroof drain
Sunroof drain
I Know this is discussed 1000 Times .
Problem with clogged drains. Acces from The sunroof is easy. But i would like to Know where are this tubes ending. Where is the Exit. Somewhere in the Engine compartment? Or this Place behind the Wheel well liner? Thank you for assistance.
The front ones drain out of one of the little valves along the lower valence. I think the roof drains are just behind the front wheel well. The rear should come out just behind the wheel well and there are several there especially if you have 4zone climate.
I used weed-eater string trimmer to run through them and clean 'em out. worked out pretty well but I should probably do it again this summer.
I took apart the a pillar trim and the headliner. Could get acces to the hose. Disconnect the hose from the reservoir which is sitting in the sunroof frame. Found a hose with onother green smaller hose inside. This is i didnt know. The green tube was split. Dont think its normal. I used a bowden cable to clean the smaller tube. I can get inside for about 120 cm. Then its stuck. Normal or it should stick out somewhere? I am really dissapointed this cant be solved. Would like ask:
The inner green tube has to be completely inside the grey hose or it has to stick outside and ending in the reservoir?
How to replace the entire green tube if its closed and cant be cleaned?
I can't help answer that. I didn't take mine apart, I just ran the weed eater line down there and then ran some hot water through it. I also pulled the little valve off the bottom of the car and took it in the house and cleaned it in the sink. I haven't had any leaks so it must have worked.
For what it's worth here is some explanation of how to get in a bit further than you already have maybe? http://www.renntech.org/forums/topic...r-floor/page-2
Hey - that was my writeup.. it's becoming famous now?
Well I am nothing if not a semi-decent researcher who likes helping others out. I'm slightly active on several different forums but what's funny is your post came up in a google search.
I've said if it weren't for car forums and youtube I'd be taking my stuff to the shop a lot more often than doing it myself.
bdschet
07-24-2016 06:24 PM
yvesvidal
04-14-2016 11:47 AM
pdxm5
03-28-2016 02:48 PM
