PSM Failure Workshop
Old Feb 25, 2014 | 10:13 AM
lrolf's Avatar
lrolf is infamous around these parts
I get the following on my Cayenne 2004 S
every morning, when I start my car, my PSM failure light is fine. However, after an average of 15 minutes driving, and it always happens when car is idle or in traffic, car/engine shuts down. When I turn the car back on, the PSM failure light shows up. Car never shuts down when PSM failure light is on. When the PSM light is on the engine is performing badly.
Any help appriciated
Old Feb 25, 2014 | 10:39 AM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
Find out what the fault codes are, if not you will have to take it to the dealer and they will tell you.
Old Feb 25, 2014 | 10:49 AM
lrolf's Avatar
There are many different fault codes most of them are DME related saying that DME is faulty but if you turn off the engine and clear the codes everything is working again until what I described in my post happens.
Old Aug 20, 2014 | 02:45 PM
paulwu's Avatar
paulwu is infamous around these parts
Hi,
I am having all exact symptoms as you have on my 04 cayenne-s. Any update? Any help will be great appreciated!
Thanks,
Old Aug 20, 2014 | 10:15 PM
lrolf's Avatar
Replace main control unit
I had to replace the main control unit, i think it is called DME, cost about 2000 euros
Good luck
Old Aug 24, 2014 | 01:11 PM
DLF's Avatar
DLF
DLF is infamous around these parts
I saw this display once while troubleshooting a surging problem on my 04 CS . I fitted some new "Bosch"MAF Sensors (which turned out to be fakes, I eventually got the right ones though), anyway I had to temporarily disconnect the MAF sensors to get the car started . With the MAF sensors disconnected, the car will start up but may idle badly, and you will get the PSM Failure display.
So long story short, maybe check the plugs on your MAF sensors are not loose, or maybe you have a faulty MAF sensor.
Old Sep 3, 2014 | 10:18 PM
paulwu's Avatar
Good luck
Thanks for the help! Guess I need to replace the DME as well; but only authorized Porsche dealer can code and adapt a new DME and they are talking about couple thousand dollars job too. No wonder this car is depreciate so much year and year!
Old Sep 3, 2014 | 11:48 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I can get you lined up with a ecu for a few hundred. If interested PM me.
Old Oct 15, 2014 | 08:08 AM
paulwu's Avatar
Finally have replaced a new DME; but after running for 15-20min still same issue ! Thus it is not the DME . Will try the crankshaft speed sensor the next.
Any input will be great appreciated !
Old Oct 16, 2014 | 12:11 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Before you replace anything else... you need to obtain a Durametric or take it to someone with a PIWIS and read out the codes that show up. Then we can talk about next steps...
Old Oct 16, 2014 | 07:53 AM
paulwu's Avatar
There is a P0035 crankshaft position sensor "A" code stored in the DME; are there 2 crankshaft sensors A & B? I believe there is only one crank position speed sensor. Also there is a "DME" error stored in the tiptronic.
Thanks,
Old Oct 16, 2014 | 08:03 AM
Moderator
It looks like you may be using a standard OBDII code reader, which gives universal P-4 digit codes. The problem here is that your standard OBDII reader is only made to read out emissions related codes. It will not read out all codes in your CANBUS computer modules. So you are trying to diagnose the issue without looking at the full picture. Do you have a Porsche Independent Mechanic that can read out all faults in all modules? Just trying to give you the best advice from what I see..
FWIW, a bad crankcase sensor and/or bad cam sensor can definitely stop a car without any warning.
Old Oct 16, 2014 | 08:31 AM
paulwu's Avatar
Thank you much for the info, I have a "Launch" also "Val-com" doing for diagnostic. Kind of challenge task this time; will keep you posted!
Old Oct 16, 2014 | 08:54 AM
Moderator
Cool! I haven't heard of "Launch", but I think you mean "VAG COM", right? I know that is for Audi/VW guys... not sure if it is plug and play with Porsche. However, from what I understand, the Durametric program is based off of VAG COM for Porsche.
Old Feb 11, 2016 | 09:26 AM
DLF's Avatar
DLF
I just thought I'd add something to this thread after my recent experience. I also experienced an intermittent "PSM Failure Workshop" warning on my 04 CS.
At first it would occur only on start up, not from a cold start I should add, usually when starting from an intermediate temperature, like for example after driving to the supermarket and leaving her parking for an hour or so. No problem when starting from cold or when fully warmed up. I'm not sure of the significance of this, but it's just the way it was. The engine would turn over for longer then usual before starting and I would get the "PSM Failure Workshop" warning. If I drove with the warning on, performance was notably poor (misfiring). The warning would go away immediately if I switched off and started again.
The problem later escalated (after a few months) to stalling at idle and eventually to stalling even while cruising (but then recovering).
Anyway drawing fault codes gave the following codes
I replaced the crankshaft position sensor to solve the problem.
It's actually quite an easy job, most difficult part was to get it unplugged !
pwdrhound
Sep 13, 2016 10:44 AM
randalldahme
Feb 19, 2016 03:56 PM
DYL 911
Oct 1, 2015 02:47 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
ophtho
Sep 18, 2015 03:00 PM
