Off-road tires
Old Aug 22, 2022 | 05:30 AM
Jeremyvmd09's Avatar
Jeremyvmd09 is infamous around these parts
Off-road tires
I recently purchased a 11 cayenne s with the 22” turbo 2 wheels. I do a fair bit of upland hunting which often requires driving on poorly maintained dirt roads. I wanted tires with a little more tread depth than the factory 285/35r22 tire options. I found a set I like in 285/45r22 which are almost 2” larger. Saw a photo in a old thread on here that made it seem like they fit. Anyone running that size on a stock cayenne? I’m not above getting a 2” lift if necessary but would prefer not to if I can avoid it.
edited to add. I did find some 275/45r22s that look like they would work as well if I’m less likely to have issues with those
Old Aug 25, 2022 | 07:02 PM
mep1811's Avatar
mep1811 is infamous around these parts
I highly recommend you get 18" wheels . There is not enough sidewall with 22" wheels to resist rocks. 18" wheels will also give you a large selection of all terrain tires to choose from. ` My 2013 with A/T tires
Old Aug 25, 2022 | 07:26 PM
Thankfully I don’t need to worry about rocks. Just slightly rutted dirt roads. But I’m thinking if I want any decent tread I need smaller wheels.
Old Aug 25, 2022 | 08:10 PM
mep1811's Avatar
Rutted roads will have rocks and with about an inch or so of side wall it will not take much to rip a soft street tire's sidewall. 18" wheels will solve your problem
Old Aug 25, 2022 | 08:12 PM
South Jersey doesn’t do rocks (any bigger than gravel) lol. But I get the idea. I’ll look into some wheels for hunting season. Used to do a lot of rock crawling up in coal country pa (roush creek and paragon back in the day) so I’m familiar. Been a few years since I did any of that (sold off my crawler). Was more concerned with the road being muddy/traction
Old Aug 25, 2022 | 08:20 PM
mep1811's Avatar
OK Grew up in New Jersey and hunted a lot of Grouse and Pheasant there.
Old Oct 9, 2022 | 04:41 PM
Kwest127's Avatar
Kwest127 is infamous around these parts
The offroad tires looks great
Old Jan 3, 2023 | 01:41 PM
Rvca3112's Avatar
Rvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant future
Where about are you in south Jersey? I’m in central Jersey/ocean county
Old Jan 3, 2023 | 02:06 PM
I totally forgot about this thread lol. I’m in Williamstown but spend time in Waretown at the marina. if you’re not already you should join schattenbaum Pca. Great group of guys
I ended up with 265/50r20 cooper at3 4s, in the new mantra the fox wheels.
CayenneS12
Cayenne
Jan 4, 2023 05:29 AM
mansour.m
Wheels/Tires
Aug 20, 2012 08:45 PM
canberk
Cayenne 955/957
Apr 5, 2008 10:45 AM
GoldenPEPPA
Cayenne 955/957
Jun 24, 2006 02:27 PM
