LSD buster
Rating: Thread Rating: 4 votes, 5.00 average.
Old Apr 20, 2010 | 06:47 PM
  #106
mikymu's Avatar
mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !
WOW, the 997 LSD inner look really cheaply made compare with 996. That is too bad that Porsche fall into the same trap of cost saving by sacrificing quality. I heard that the new titanium center exhaust found on GT3 R and RS are cheaply made to save cost and it does not hold up to rigor of race and the damn thing has been blowing up. I feel better the fact that my ramps have been replaced with your beefy GT gears
Old Apr 21, 2010 | 12:47 PM
  #107
GTgears's Avatar
GTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond repute
Originally Posted by Joeacc
Chances are that was my 996 gt3 LSD. Matt had excellent turn around time on my LSD rebuild. He received it at 1pm and had it shipped out with ups the same day! I should have it all back in today.
Thanks for the kudos. That was in fact your LSD.
Old Apr 21, 2010 | 02:09 PM
  #108
GT3 Mike's Avatar
GT3 Mike is a name known to allGT3 Mike is a name known to allGT3 Mike is a name known to allGT3 Mike is a name known to allGT3 Mike is a name known to allGT3 Mike is a name known to all
This is the most imformative thread that I read! I would name it the best technical thread for 2009:-) thanks to Matt and Mikymu.
I just bought a 996 Gt3 and it needed a LSD rebuild! Matt, can you PM with quote? I will ship it to you.
Michael
Old Apr 21, 2010 | 02:54 PM
  #109
GTgears's Avatar
...sent
Old Apr 21, 2010 | 09:57 PM
  #110
ex10psi's Avatar
ex10psi is infamous around these parts
i bet no one has seen LSD damage like this one! 996 GT3
the damage you see is on a REBUILT diff that my porsche stealer performed under warranty with factory OE 996 gt3 parts. this damage occured after 1yr and 1k miles of NON track, STREET only driving.
warranty denied... stealer and PCNA rep said: "customer abuse. possibly hit a patch of black ice. taking corners too hard. or worse, he may have driven the 996 gt3 on a race track! oh the horror!"
so stealer "graciously" offered to rebuild the diff again at a bargin discounted price of $3,000. eh... i said "no thanks" and diff went to matt at guards and matt did it right. i guess i can now go drive on "black ice" and take corners "too hard". stupid stealer
great thread and info here, thanks for letting me vent!
Old Apr 22, 2010 | 12:04 AM
  #111
mikymu's Avatar
Michael
Excellent Michael. Matt will take good care of you.
WOW! They really botch the job and looks horrible after only 1K miles of none track use and they want to charge $3K??? Unbelievable. You earn the right to vent buddy!
Old Apr 22, 2010 | 11:10 AM
  #112
GT3 Mike's Avatar
Talked to Matt and he was helpful. I will take the LSD out and ship to Matt. My next track day is May22nd...Can't wait!
Old Apr 22, 2010 | 12:00 PM
  #113
GTgears's Avatar
I'm getting a number of questions about the ring gear, so I thought I would make a post about it. Here's a picture of the LSD with the ring gear still attached:
Here's with the ring gear removed:
I encourage people to remove the ring gear before sending the LSD to me because of the risk of damage more than anything else. A ring and pinion set is almost $3000. They are matched sets and if the ring is damaged in shipping the whole set needs replacement. Furthermore, because it requires resetting the pinion depth, along with ring gear preload and backlash, it's generally $1000 or more in labor to put into the gearbox.
While insurance is a wonderful thing for if UPS messes it up, it usually takes up to 100 days to get paid. And that's if they pay it. They often claim that it was packaged inadequately and dump it back in your lap.
So, if people have the ability to remove and reinstall the ring gear themselves on their end it's a much safer approach than shipping it to me with the ring attached. If you have no other option, I am happy to remove and reinstall it for you. I do add $50 in labor for the extra time and it does increase the shipping charges a bit. I just figured I would put it out there because so many of the DIYers doing this work have been asking me specifically about the ring gear. This puts it up there for all to see and ask questions if it's not clear.
regards,
Matt
Old Apr 22, 2010 | 02:57 PM
  #114
cfjan's Avatar
cfjan is infamous around these parts
Matt,
Are there any trick on removing the ring gear from the diff?!
Old Apr 22, 2010 | 03:08 PM
  #115
GTgears's Avatar
It's on there at about 125ft/lbs so air tools are really the way to go for getting it off.
Then you've got to heat it a bit and actually wack it loose of the differential body with a rubber/plastic mallet. It's on there pretty tight and doesn't want to come off too easily.
For reinstallation, we "chock" it in a vise (with aluminum between the vise teeth and diff. body to avoid marring it) and torque them back on in a start pattern like you would a flywheel. I generally bring it up to about 75-85ft/lbs on all bolts and then take it up to 125 from there.
Old Apr 22, 2010 | 03:12 PM
  #116
cfjan's Avatar
Thanks for the info.. !!
Do you use a torch to heat up the ring gear?
Old Apr 22, 2010 | 04:29 PM
  #117
GTgears's Avatar
Yes, we heat the ring gear with a torch. There's a number of interference fits parts in a Porsche gearbox and heat is often used to make removal or installation easier.
On reinstallation, you can generally get it to seat far enough to get the first row of threads started on a few bolts. Then you systematically use the bolts to pull it tight in an equalized and even pattern. Once you've got it pulled on and in place with 3 or 4 bolts you can put the rest in and start torquing them.
Old Apr 22, 2010 | 04:34 PM
  #118
cfjan's Avatar
Very useful information, thanks Matt!
Not that I plan to do this myself anytime soon (if ever!) but I appreciate that you are always willing to share your knowledge!
Old Apr 22, 2010 | 04:51 PM
  #119
GTgears's Avatar
You're welcome. I try. I had a guy call me today and ask some questions about a differential. When we were done he apologized for not buying something. That's just not how I look at it. I know some vendors act like if you aren't spending money you are wasting their time. That's not me. I'm happy to help, and educate, and also to learn.
Old Apr 22, 2010 | 05:40 PM
  #120
cfjan's Avatar
That is great, Matt.. and it is behavior like this that would make me a future customer!
I remember another vendor basically just shut me off when I asked how their product works (I asked for a side by side comparison between their "improved" version and the stock version). I was told that if they show that to me, then what's the point..
My take on that is.. first, you need to convince me that it works by showing me what's the difference and tell me why it makes a difference.. second, even if I know exactly what's the difference.. it is not like I have a CNC machine or mill/lathe at home that I can just make it at home.. LOL! So just from their very defensive response, it completed turned me off on their products.
Anyway, like I said, I appreciate you always taking the time to answer our questions. You are a great asset to the forum.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
