997 GT3 Rear License Plate
Old Apr 10, 2007 | 07:51 PM
sasportas's Avatar
Awaiting Email Confirmation
sasportas has a spectacular aura aboutsasportas has a spectacular aura about
Anybody have difficulty mounting their rear license plate? Mine came without any plastic housing to mount the rear plate. Is this normal or just a missing part? Also, seems like the vertical space is very tight. I noticed paint worn away from the vibration of the plate rubbing against the lower portion of the bumper. It seems that license plate frames don't fit very well either.
Old Apr 10, 2007 | 07:55 PM
20C4S's Avatar
go get the plastic backing piece. i don't know why Porsche decided to go even cheaper this time but mine did arrive just like urs. the part cost like 10 bucks or so.
Old Apr 10, 2007 | 10:00 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
During a new PDI, everyone at the dealer I work at including myself will get the plate bracket from the parts dept. and put it on, seems like 987's come with them 997's do not, for the most part.
Old Apr 10, 2007 | 10:48 PM
watt's Avatar
watt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to behold
i wonder if any of those 5 or 10 front brackets i nvere put on would fit. also the screws are too small yo hold the chp frame w/o washers...
Old Apr 10, 2007 | 11:05 PM
20C4S's Avatar
nope watt the front one won't work.
Old Apr 12, 2007 | 06:05 PM
Andrew D.'s Avatar
Andrew D. is infamous around these parts
I had the same problem. Part #997-701-113-00-01C takes care of the problem. Also get two tap screws - Part #999-919-228-A2. It should cost you less than $25.00.
Old Apr 14, 2007 | 12:19 AM
ClubCoupe's Avatar
ClubCoupe is infamous around these parts
Who needs a license plate? Ask Thomas when he will put one on...
Old Apr 14, 2007 | 12:48 AM
TUUNER's Avatar
TUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant future
...I have commitment issues!!!
Old Apr 14, 2007 | 08:49 AM
Alex13188's Avatar
Alex13188 is infamous around these parts
Out of curiosity how does everyone get away with having no plate? In massachusetts I think they can shoot you for that hahaha
Old Apr 18, 2007 | 06:30 PM
princetonymc's Avatar
princetonymc is infamous around these parts
I still have the screw set that came with the front bracket which I have not mounted. Are the tap screws the shorter of the screws(there are long ones and short ones with slightly larger heads) with the pointed ends or are they blunt ended. I don't want to install the incorrect screws and damage the car using the wrong parts.
Old Apr 18, 2007 | 07:11 PM
Andrew D.'s Avatar
They are the longer ones (size 5x28) with the pointed ends.
Old Apr 18, 2007 | 08:40 PM
sasportas's Avatar
plates
My dealer is still trying to figure out why my car didn't come with the rear license bracket kit.
Old Apr 18, 2007 | 09:23 PM
Thanks Andrew for the quick response.
Old Apr 18, 2007 | 10:59 PM
Andrew D.'s Avatar
Mine was delivered without one, too.
Old Apr 21, 2007 | 07:23 PM
I got the bracket. Do I need to predrill small holes with a drill bit prior to screwing in the tap screws?
