Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Exhaust Options?
Old Jun 26, 2008 | 04:53 PM
Motoracer's Avatar
Motoracer is infamous around these parts
Exhaust Options?
Just placed the order today for my new MINI. Want to look into exhaust options.
What are the options? Anyone have links to sound clips?
Thanks!
-Kyle
Old Jun 26, 2008 | 05:02 PM
orhanz33's Avatar
orhanz33 is infamous around these parts
Congrats man, where did you order?
Alta makes a turbo-back. They also offer a plug and play ECU with pretty good gains.
http://www.altaminiperformance.com/p...ory=6&model=11
http://www.youtube.com/watch?v=oAP718gOuPA
Old Jun 26, 2008 | 08:18 PM
Motoracer's Avatar
Nice! Thanks for the links! I will look into them in a bit.
I put in the order this morning and the dealer said it should be pulled into production today or tomorrow and should be HERE in 4 WEEKS! I'm excited!
Old Jun 27, 2008 | 03:45 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Fast build. You'll use it as DD?
Old Jun 27, 2008 | 07:30 AM
Motoracer's Avatar
yes. Will be a fun little daily driver. With gas prices what they are, I think this will fit the job perfectly.
Old Jun 27, 2008 | 08:13 AM
trojanman's Avatar
Welcome to the OC, bitch!
trojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant future
Basically you have to decide what you want to accomplish. If it is sound only, then a less expensive Cat-back system will work fine.
Alta is perhaps the most recognizable name in Mini mods, but it is by no means the only. Some people would also say it is far from the best.
You might also consider, in no particular order:
Milltek, Borla, Way Motor Works, Invidia, Meisterschaft, and a semi-custom Magnaflow setup - the least expensive way to go. Most of these are $600-$900, except for the magnaflow which will cost about $300.
If you want any kind of performance gains, you MUST go with a turbo-back exhaust that includes new high-flow cats. The options here are: Alta, Way Motor Works, Exhaust Depot (florida - possibly the best sounding system), Revolution Mini Works (in development). These all cost $1600-$1800, except for Exhaust Depot, which costs about $800.
For my money, Exhaust Depot can't be beat!
Old Jun 27, 2008 | 08:16 AM
Motoracer's Avatar
I will look into Exhaust Depot now! Thanks for the tip!
Old Jun 29, 2008 | 08:17 AM
spyderman33's Avatar
spyderman33 is infamous around these parts
I personally like the Borla Street exhaust... Go to youtube and search for Mini Cooper Exhaust.. you'll get a ton of hits back...
good luck.
Sep 14, 2015 06:42 PM
