Lift Points on a Panamera
Old Oct 7, 2020 | 01:08 PM
  #31
stealthn's Avatar
stealthn is infamous around these parts
Yes but you have to measure the jack points, the 911 is probably the 5000 and the Cayenne is probably the 7000 for jack points. That’s why I went with the setup I have
Old Oct 1, 2024 | 10:58 AM
  #32
negb's Avatar
negb is infamous around these parts
Originally Posted by lesliew
has anybody replaced 97050458501 socke-jacki A - outer ? Can't see any fixing bolt or screw... how to remove old one ?
Old Oct 2, 2024 | 05:58 AM
  #33
Marc13190's Avatar
Marc13190 is infamous around these parts
You pull part center and you pull set
Old Oct 2, 2024 | 12:50 PM
  #34
negb's Avatar
no need to remove side member trim (part no.1) ? that socket jack is pushed fully inside somehow ....
Old May 14, 2025 | 06:11 AM
  #35
negb's Avatar
You were absolutely correct, just needed to use a bit more force on a flat screw driver
ciaka
Aug 25, 2018 11:13 AM
ciaka
May 18, 2018 08:36 PM
pteck
Feb 16, 2016 10:44 PM
gregp714
Sep 5, 2014 10:02 PM
timf
Nov 5, 2012 12:09 PM
