Suggested Tires - 2013 Panamera GTS
Old Dec 5, 2013 | 02:03 PM
cole328's Avatar
cole328 is a glorious beacon of lightcole328 is a glorious beacon of lightcole328 is a glorious beacon of lightcole328 is a glorious beacon of lightcole328 is a glorious beacon of lightcole328 is a glorious beacon of light
Gents...I believe there was some prior input on this topic, but for the life of me I cannot find it. So, thanks in advance.
I have the dreaded Pirelli's on my OEM 20's, and am likely to replace the tires in January (I at least got 9000 miles out of them). I am 100% going to the Michelin's, but wanted advice re: PS2 or the PSS. I believe there was definite preference to the PSS, but could not recall.
Also, on most of my prior sports cars (997S, two M3's), etc, I was generally able to keep the fronts for every 2x I had to replace the rears. This time, while not exactly equal, the fronts are wearing down pretty hard as well, such that I likely need to replace all four at the same time. I assume this makes sense given that this car is AWD?
Thanks!
Old Dec 5, 2013 | 02:39 PM
NiceCar's Avatar
NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !
I am having Michelin PS2 installed right now. The GTS came with Goodyears, which I was completely happy with, but I wanted to try the Michelins. I'll let you know what I think of them.
Old Dec 5, 2013 | 05:12 PM
tonyep's Avatar
tonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of light
The fronts definitely wears equally as the rears on mine, might be the heavier front. Reaching 10k on the Pirellis and I am losing tractions on launch control.
I've read that the PSS are quitter than the PS2 and perform as well while being cheaper!
Old Dec 5, 2013 | 06:00 PM
cole328's Avatar
Thanks tony...I am at 7500 miles, and still have not done a Launch Control...ha I am such a puss!! how awesome is it? Issue is that I am not really sure where to do it?H have you ever done it just blazing away from a stoplight?
I am def leaning toward the PSS.....regardless, anything will be better than the Pirelli's they just suck
Old Dec 5, 2013 | 09:22 PM
NiceCar's Avatar
Launch Control is pretty awesome. Don't do it if you have whiplash!
Old Dec 6, 2013 | 07:59 AM
Gelmachine's Avatar
Gelmachine is just really niceGelmachine is just really niceGelmachine is just really niceGelmachine is just really nice
Gents - any experience with the Bridgestone Potenza's? I've used them in the past on BMWs and have had good experiences!
I'm in the same boat with my '14 GTS, I have the all season Pirelli's and need to get rid of them in the spring.
Old Dec 6, 2013 | 11:32 AM
toughluck's Avatar
toughluck is infamous around these parts
I too came from a BMW which had Bridgestone Potenza RFT and they were horrible. For slightly more money, I decided to replace them with Michelin PSS and they are wonderful. They have better grip (dry and wet), suppose to last longer and are a lot quieter.
Now in my panamera, I moved from Continentals to Michelin PSS. Again, the Michelin tires are quieter and grip better. I would definitely get either PS2 or PSS again. I think PSS and PS2 cost about the same and grip is equal.
Old Dec 6, 2013 | 12:22 PM
cole328's Avatar
Hey there...With the new PSS', assuming they have stiffer sidewalls than conti or Pirelli's, what kind of tire pressure are you running as a DD for best performance handling? I am at like 43 cold on the Pirelli's since they are so squirrely sidewalls....
Old Dec 7, 2013 | 04:54 PM
tonyep's Avatar
You definitely gotta launch this car once to know how awesome it is! I do it on empty backroad. Plenty around here in the Bay Area.
Old Dec 7, 2013 | 04:57 PM
NiceCar's Avatar
I'm in the Bay Area and can't think of many places I could use LC. Do you have any suggestions?
I got the PS2s today and they feel very comfortable (even at 42/47 pressures) on the road and they're quiet as far as I can tell so far. Don't know about grip, I'll have to test that out.
Old Dec 7, 2013 | 10:04 PM
tonyep's Avatar
South Bay has lots of roads to do that. Roads there are wider and some are definitely empty during the weekends.
Old Dec 7, 2013 | 10:16 PM
NiceCar's Avatar
I'm just north of SF and you don't find many empty roads around here. You have to go out to the country.
Old Dec 8, 2013 | 02:53 PM
DJF911's Avatar
DJF911 is infamous around these parts
I have just over 13k on my GTS and PS2 still look pretty good but prob only have one more summer. I like the PSS as my next tire. I have not yet done launch control.
Old Dec 10, 2013 | 05:53 PM
cole328's Avatar
Are you running 42/47 cold pressures? weird split between front and rear...what model panny?
Old Dec 10, 2013 | 10:05 PM
NiceCar's Avatar
That's about what was set on my new PS2s. After a long drive today, over all sorts of roads, I think the pressure is too high. It's not quite as smooth going over rough roads/train tracks/etc. as the old Goodyears which had lower pressure. I'm going to lower the pressure all around 3-4 psi and try again.
