Front end noise
Old Nov 6, 2015 | 06:35 AM
  #61
allroadusa's Avatar
allroadusa has a spectacular aura aboutallroadusa has a spectacular aura about
Juste a small testimony on this topic. As my PTT had to renew the Porsche Approved warranty, I mentioned a front noise over bumps.
It took a long time for fixing it. 3 weeks in the shop and they changed everything : lower and upper control arms, sway bar and finally air struts.
So far so good, noise is gone. PTT is good to go for one another year of PA.
Old Nov 25, 2015 | 08:42 PM
  #62
skidmarkz's Avatar
skidmarkz is infamous around these parts
Just got my 2013 with 17k miles on it back for the same issue. Seems like the clunk over bumps is gone now - they found the bushings on the upper control arms to be bad/loose.
Old Dec 9, 2015 | 09:10 PM
  #63
PV=nRT.'s Avatar
PV=nRT. is infamous around these parts
The website InsaneGarage.com has a post that may seems to address the front end noise issue. (I have just scanned this thread so I apologize if it is previously mentioned or it is off base to the thread). That post and related issues are also addressed in the following video:
The InsaneGarage post is at 35 min 38 sec in the video.
Old Nov 6, 2016 | 04:56 AM
  #64
negb's Avatar
negb is infamous around these parts
Originally Posted by MackSea
Are you sure you're not hearing tire skip? Mine did that when backing out of my driveway in the morning (cold air, cold tires). Everyone says it is normal for Porsche and maybe because of AWS (had a 4S). Interestingly, my BMW 550 with x drive does not skip the front tires having driven it even in single digit temps and the BMW has almost as much tire on the road as the Porsche.
Yes, I've had tire slipping when making full turn on wet road when air started almost freezing and I still had summer tires with only 4mm thread. Changed to new winter tires and no slipping anymore at the same scenario.
Old Nov 6, 2016 | 05:24 AM
  #65
negb's Avatar
Originally Posted by bornagain1973
I just got a 2010 4s with about 35k on it.. and I hear some creaks from the front right side
creaks when turning ? I hope I have found the reason .... Was twice at Porsche dealer/service and twice they reported to me that suspension is ideal ... So for Porsche it means ideal ? Or its ideal while is covered by warranty ?!
Old Nov 9, 2016 | 08:09 AM
  #66
negb's Avatar
Porsche confirmed that this drive shaft play is normal, and it has to be like that, and it can be very different on other side ... I'm
Old Nov 14, 2016 | 07:22 AM
  #67
verdugo135's Avatar
verdugo135 is infamous around these parts
I've got an 11 4s that I just picked up and had the same distinctive noises up front, especially when cold, especially in the morning. Mine sounds like an old spring mattress. Luckily it has a CPO warranty from previous owner. They are replacing upper and lower control arms up front. Lets hope this fixes the issue.
On another note, I also mentioned an erractic tach needle to the service tech. At cruising speeds, the needle sort of wiggles up and down, though I don't feel the engine surging. Anyone else had this happen to them?
Old Nov 14, 2016 | 02:13 PM
  #68
negb's Avatar
Have you checked drive shafts/front differential what is shown in my videos ?
Old Nov 17, 2016 | 02:20 PM
  #69
XLR82XS's Avatar
Make sure they check and/or replace the sway bar bushings. They are a known culprit.
Old Nov 21, 2016 | 05:31 AM
  #70
Lboogie78's Avatar
Lboogie78 is infamous around these parts
I have a 970TT and i've notice in the am esp when its kind of cold outside when i drive over speed bumps my cars makes a kind of noise.. is this bad? I have the air shocks.
Old Dec 30, 2017 | 08:27 AM
  #71
CLKFAN's Avatar
CLKFAN is infamous around these parts
After reading through this thread I noticed that all of you have all wheel drive cars and air suspension PTT and 4s. Did I miss any rear wheel drive cars here?
Old Jan 2, 2018 | 08:52 AM
  #72
Big_Tex's Avatar
Big_Tex is infamous around these parts
RWD here and no air suspension. Just bought a 2010 S, 61k miles on it. Lovely car but lots of front end clunks. Going to live with it for now but will be addressed in time.
Old Jan 5, 2018 | 06:45 AM
  #73
Panamerian's Avatar
Panamerian is infamous around these parts
Yes. 2013 S in the shop right now for control arms and sway bar bushings. I do have the air suspension.
Old Jun 25, 2018 | 06:49 PM
  #74
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
Seems like I’ll be joining you guys with this issue. I have a 2015 Panamera 4S with 49K miles and I have the clunky noise from the front end while driving slow and turning. I will call the dealer and schedule to bring it in and start the process...
Old Jun 28, 2018 | 03:17 PM
  #75
ciaka's Avatar
Most likely clunking coming out of lower control arms bushings being shot. Hard to tell but possible.
Squeaking is most likely due to upper control arms bushings shot. These are usually the ones on either side of shock and very difficult to detect damage as they are squeezed between metal and you cannot look between at the rubber.
From my experience sway bar bushings are last to cause this. They have so little room to move, and are very tight already.
I am sure your dealer will tell you both, if you have these noises.
