Panamera fuel filler door hinge
Old Dec 28, 2018 | 05:37 PM
ajwithers's Avatar
ajwithers is infamous around these parts
Originally Posted by ciaka
Level if difficulty about 3 of 10.
pm coming your way soon.
I would wait, trying to take this apart not trivial and easy to make mistake, and damage car.
Having 150k car neccesitates official service manual. Only way to do things right, and not depreciate value of your car whild doing it.
Service manual... where do I find one: looking for a 2011 PTT. TIA
Old Dec 28, 2018 | 10:44 PM
ciaka's Avatar
believe it or not, some found on ebay searching for oem service manual. I looked briefly found few for under 20 bucks.
Old May 5, 2019 | 10:44 PM
dougcayenne's Avatar
dougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura about
my 2016 pan4 fuel door hinge holding the door is broken tonight. I don't know how? I realize when I open it while filling the gas at Chevron gas station. I can close it. I already make an appointment to bring my car to Porsche dealer to get fix. My car is still under warranty. This task is not an easy, I don't see any screw to remove it. I see note from Ciaka how to DIY.
Another run to dealer ...
Old May 8, 2019 | 05:05 PM
Dartmouth's Avatar
Dartmouth is infamous around these parts
Same here. I bought a fuel filler pocket on ebay for $75 with a white cover. Dropped it off my Porsche certified body shop to paint the cover. I'm going to carefully remove the old one and replace with the used one I bought that looks like a new one. Porsche wants about $250 for the pocket and cover flap new from Suncoast. Little nervouse about doing it but I'm patient and mechanically skilled. So I'll post after I finish.
Old May 17, 2019 | 10:20 PM
Done !!! my wife 2016 PAN4 is under warranty. The fuel filler door is replaced under warranty - part number is 970-504-194-10 Fuel Filler Cup . Happy !!!
I got a 2018 PAN4s Volcano Grey color and red interior, a fully loaded car with all options, $132K sticker price. The 2018 PAN4S drives FANTASTIC, quiet and very Smooth d ... I feel lag and hear no sound of porsche exhaust sound when I accelerate full throttle from 65 to 90. thermal insulated glass option. LOL ... Just for a minute on I880 freeway. We Love the new car .... 2018 CPO PAN4 Hybrid is faster ... and only $84K now. $125K new ... LOL ...
Old Nov 30, 2020 | 12:40 AM
murci930's Avatar
murci930 is infamous around these parts
Literally just fixed the hinge on my filler. The pin in the hinge rode up and I was able to put back into place.
these forums are the absolute best!
Old Dec 9, 2020 | 09:28 PM
murci930's Avatar
Does anyone know where I can buy the gas cap holder (when filling, put it into the hole for it to rest in)... cant seem to locate
Old Dec 15, 2020 | 02:39 PM
Turbotod's Avatar
Turbotod is infamous around these parts
Hello murci930, I'm pretty sure all I need to do is strighten or realign this fuel door hinge pin, how do I get to it?
Thanks! Turbotod
Old Dec 16, 2020 | 09:29 AM
clc3251's Avatar
5 Year Member
clc3251 is infamous around these parts
Thanks! Turbotod
I just did this. You don't have to destroy your fuel door pocket. Take the outer door off first by putting a small flathead screwdriver into the slot and sliding the cover off. You just need to move the locking pin back an inch or so by loosening the two phillips head screws and moving it towards the rear of the car slightly. This will free up the back of the pocket. If you push a small sharp flathead screwdriver through the two small oval slots at the rear of the pocket, you will be able to put in two paint can openers. push in on the paint can openers, which will disengage the locking tabs, and pull out and the rear of the pocket should pop free. You can then slide the whole thing out towards the rear without touching the two forward ovals. You have to take it out towards the rear because the hinge goes far forward into the body and won't just pull out without sliding it to the rear. I had the same problem with the hinge pin walking up causing the door to wobble. I put the pin back in place and melted the end of the pin slightly flat with a soldering iron so that it wouldn't walk out again, hopefully.
Old Dec 16, 2020 | 07:28 PM
ciaka's Avatar
I made a DIY for this while back.
Read through before you start. Take care.
Click here
Thanks! Turbotod
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
NIKAS
Aug 20, 2019 07:53 PM
XLR82XS
Oct 5, 2015 07:02 AM
simoncpw
Sep 8, 2015 10:55 PM
