DIY: Panamera Oil Change
Old May 27, 2021 | 12:01 PM
  #31
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Originally Posted by Nikita4Ever
where did you get the washers?
the last time I ordered from Amazon, oil leaked everywhere the next day
Ordered about 8 from FCP Euro, along with other stuff...
You torque with torque wrench? Al type correct?
Old May 28, 2021 | 12:36 PM
  #32
Nikita4Ever's Avatar
Nikita4Ever is infamous around these parts
The crappy washer was the problem. Went back to OEM washer and it was fine. No need for a torque wrench on a drain plug.
Old Jun 9, 2021 | 10:45 PM
  #33
jzchen's Avatar
5 Year Member
Had to pull of the huge under cover to access the PDK fluid drain plug. Low and behold there was a slight leak at the drain plug, (plug reused twice new gasket torqued to 30 Nm). Loosened slightly then retorqued to 31 Nm. Cleaned up and now monitoring, I left the cover off for now until I finish the intermediate service completely...
Old Jun 19, 2021 | 09:38 AM
  #34
jzchen's Avatar
5 Year Member
31 Nm on my old never recalibrated Craftsman torque wrench stopped the seeping.
Old Sep 1, 2021 | 02:19 PM
  #35
clc3251's Avatar
5 Year Member
clc3251 is infamous around these parts
Did this today. Took 9.5 quarts to bring a 2012 turbo up to 4/5 bars full.
Old Jul 4, 2022 | 01:21 AM
  #36
vkb123's Avatar
5 Year Member
vkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond repute
Did oil change today and thought I’d share how to check the oil level using a PIWIS 2. This saves you from driving 10km or so before the instrument cluster shows the oil level on the display. I started by adding 8L upfront to get in “the range”.
1. PIWIS Tester II must be connected and ignition switched on.
2. Start the diagnostic program and select the required vehicle.
3. Select the DME control unit in the control unit overview. Press [F12] to continue.
4. Select the Maintenance/repairs menu. Press [F12] to continue.
5. Select the Oil filling function. Press [F12] to continue.
6. Start the engine and let it run until the engine oil temperature reaches 90° C (rev the engine if necessary to heat the oil and bring up the temperature).
7.The oil level measurement process starts automatically as soon as an engine oil temperature. of 90° C is reached.
8. The PIWIS 2 will display how much oil to add to bring to max full.
8. Switch off engine.
9. Add the quantity of oil displayed on the PIWIS Tester 2.
I’ve noticed the instrument cluster oil gauge is sitting between “min” and “max” (i.e. not right at the very top) but the PIWIS 2 is showing max full.
Old Oct 2, 2024 | 04:30 AM
  #37
negb's Avatar
negb is infamous around these parts
Originally Posted by ciaka
There are magnetic oil drain plugs out there. I may try one at some point to see how much metallic particulate collects on it. Not today though.
I have ordered this one
goto35
May 15, 2019 12:49 PM
MTheory
Jun 25, 2009 12:48 PM
Arnie
Audi
Feb 16, 2008 09:22 PM
KPV
Sep 28, 2003 09:43 PM
