Brighter reverse lights?? 2016 Panamera GTS
Old Jan 23, 2019 | 07:29 AM
  #31
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
Originally Posted by DogWood
Nice, glad to hear that they fit OK, is then first picture a "before"? Last picture looks whiter and brighter.
I hear you on the the 30W, there are some sketcher ones claiming up to 80W! foot print is a bit odd and reviews where mixed.
Lumens would be a better measurement to go by
I did find a pair of 50W bulbs in this same PH16W bulb type - of course they say they don't fit a Panamera but these 30W bulbs weren't supposed to work either. I may give them a try when I return from a long road trip next month.
Old Jan 23, 2019 | 08:34 AM
  #32
skiracer13's Avatar
5 Year Member
I just ordered a pair of these to try as they appear to be 100W output:
https://www.aliexpress.com/item/Erro...B&gclsrc=aw.ds
I'll report back when they've been installed.
Old Jan 23, 2019 | 09:42 AM
  #33
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
nice find, glad you are willing to try these out.
found this part of the description amusing
1.Top A Quality with 1 YEARS Warranty by Kaizen-GT LED that confirm to be manufacturer defect.
also found a lumen rating: 850 <- give a nice solid (well, relatively solid) thing to compare against
Old Jan 23, 2019 | 10:05 AM
  #34
elShiz's Avatar
5 Year Member
elShiz
Welp, unless I want to either dremel the sealed area, then rtv closed, or buy all new taillights with removable bulbs, I'm sol. Why on earth did Porsche make two different models of taillights for the exact same car (970 pre-facelift)?
Old Jan 23, 2019 | 11:24 AM
  #35
DogWood's Avatar
5 Year Member
yeah that is rather odd, I beleive you should be able to find the 'door' piece separately should you decide to pop the fixed part - also used parts are available for ~300 (just make sure they open) (ouch)
if you do go midevil on it, I would try just one first
Old Jan 23, 2019 | 02:19 PM
  #36
elShiz's Avatar
5 Year Member
elShiz
Hey Ski, would you mind doing me a solid when those new bulbs come in? Take some detailed photos of the removable cover that you and others seem to have? Maybe even a part if available? The area on the light assembly itself, is the same on both of ours, to include the raised lip that surrounds the cover once installed, and the screw hole. It's a shot in the dark, but maybe we can cut ours out and simply install the sealing cover that's available on yours. Who knows?!
Old Jan 23, 2019 | 05:03 PM
  #37
skiracer13's Avatar
5 Year Member
elShiz, they're coming from China so it will be several weeks before they arrive. I took the pics you requested below - you might also want to consider finding another complete ***'y to swap with. Another idea is to ask your local dealer to show you how to change the bulb for your car maybe there's another trick? - here's that first P/N:
P/N of the entire passenger side rear light ***'y
Note the rib along the side where the screw goes thru
The cover has a foam insert that makes a seal w/ this surface - note the threaded screw hole on top to secure it
Outside of cover lists output wattage for various markets. 16W is the highest listed, so let's hope it can handle 100W!
Here's the P/N listed on the inside of the cover w/ the foam insert removed
Old Jan 23, 2019 | 08:57 PM
  #38
DogWood's Avatar
5 Year Member
Old Jan 24, 2019 | 03:31 PM
  #39
skiracer13's Avatar
5 Year Member
So I had a chance to drive my car last night in the dark and these new 30W reverse lights make a noticeable improvement. I don't think I'll ever be able to see really well at night via side view or rear view mirrors because my window tinting is so dark, but the backup camera image is now greatly improved. I also placed my hand on the light fixture w/ bulb on and didn't feel too much warmth. I'm pretty sure that 100W bulbs will melt something that would be $$$ to fix.
I will call this exercise a success!
Old Jan 24, 2019 | 05:53 PM
  #40
rgfinnegan3's Avatar
rgfinnegan3 is infamous around these parts
I went to install the 30W bulbs, only to find that I too have the "closed" version of the backup light on my 2011 PTT. I should have checked first, before ordering the new LED's; it's easy to do, just follow skiracer13's directions. I thought for sure my car would have he newer style taillight enclosure.
Old Jan 24, 2019 | 07:52 PM
  #41
skiracer13's Avatar
5 Year Member
Maybe you do have the new style enclosure and I have the old style?
Old Jan 24, 2019 | 09:00 PM
  #42
DogWood's Avatar
5 Year Member
a real possibility, what was the manufacture date of your cars? mine was 11/2009
Old Jan 24, 2019 | 09:05 PM
  #43
elShiz's Avatar
5 Year Member
elShiz
Ski thank you very much, really appreciate it. Comparing your pics to my assembly look identical, aside from the cover itself. I'm curious if mine is meant to be cut out in case the bulb actually goes out, and thanks to DogWood we have a link to the cover.
​​​​​I think my exercise will be to order the cover/seal/screw from the link below and then cut off my solid cover.
Dude you and Ski are solid! Thank you for the link. I think I'll order #7 (cover), #8 (foam seal) and the screw, then cut out my solid cover. If it looks to fit, I'll order replacement bulbs... Welp here's goes nothin lol
Old Jan 24, 2019 | 09:17 PM
  #44
DogWood's Avatar
5 Year Member
Good luck
Old Jan 25, 2019 | 09:21 AM
  #45
skiracer13's Avatar
5 Year Member
Glad to help - here's a pic of the reverse lights on my garage door - not headlights...
Very bright and very white!
